- intalled 272 exhaust cam on ix
- need help
- Metal scraping sound...t-case?
- Blew clutch for the 3rd time!!!!! HELP
- Stock EVO - Ticking during Acceleration
- You guys using NITROUS
- chalk another winner move for the dealership
- shifting tension
- ?? for those with the Ebay o2 housing?
- March Dyno observations of parts and 20G's..
- oil feed and return line
- Part of boost problmes leading to Forge mbc
- What do you think about this setup?
- SES? opinions?
- Installed AMS GT35R
- Faster spool on Stock IX..
- BR8EIX gap them or not?
- 680cc injectors & Walbo combo?
- HELPPPP!!!....... Exedy Clutch
- question about APR wind spliter
- 05-06 rear diff question
- Drivetrain noise
- what a/r for gt35r with my mods
- Full throtle cut out????
- Who here is running this exhaust???? Need opinions about it, thanks!
- bled lifters during cam but still loud ticking - yes I searched
- Cam Gear or Cam Gears??
- Overboost
- Oil Weight/ Oil Pressure
- Oil seal...quick question
- evo 8 cams fit in evo 6 engine????
- BOV question, not stupid noob question?
- HKS GT3037s a/r comparison 0.73 vs 0.86
- bov's are so fun :)
- how to install MBC
- Best Brake Fluid Motul 600
- cams
- Power Estimate? Im excited!
- Tuning, S-AFC II vs Mail-in flash
- compresion test pretty bad, but how bad is it?
- Vendors! Who can give me the best prices on: Aeromotive, MagnaFuel, Ferrea and Stack?
- Soldering COP
- Which stroker should I get, a 2.3 or a 2.4?
- EVO HKS BOV with Pipe kit HELP!!!!!
- Defi BF gauge accuracy Bar=lbs?
- Oil Leak???
- mm... put my tilton on order today!
- tranmission fixed, now acd is leaking
- is it possible....
- Thumbs up to Blackstone Labs - Oil Report
- Customers getting their part combinations together at Buschur Racing.
- 5 speed or 6
- How good is your fuel pump really?
- o2 senors
- How much boost on my Evo??
- Greddy Evo2
- Boost leak tester
- 2 900hp Evo's in the Buschur stable.....
- Question on injectors please help!
- Boost Fluttering
- Loud Ticking Noise after shutting the car off
- Car Won't Start
- Evo Ix
- Review: Fighter's LICP and Buschurs Bullet TBE
- feelings on a garrett 60-1
- MBC question
- Spark plug question
- spark plug gap
- Snapped a hub stud tonight , on the rear
- Should I even consider the PERRIN FMIC for my EVO??
- Best/Cheapest Place for BG II Synchro Shift
- Changing transmission,transfer and acd fluids question?
- Need Advice on Exhaust
- 35R with Ported Shroud
- clutch
- hittn 1.5 to 1.7 some times on IX
- what intercooler for the IX?
- Next mods.....(opinions or advice)
- Cams
- Downpipe fitment
- Help me decide on a route to go w/ my mods
- Alky tune With Nitrous..?
- ? Sudden Power Taper at 7000 rpm+
- Starting parking lot engine build
- 15w-50 = 90psi at idle?
- Boost problems again!!!!!!!
- Overboosting!
- HKS DLi 2
- 4,500 to spend
- Full Race turbo size...which one do I want?
- GT35 and a Flash...whose running it?
- BOV Pressure Testing: HKS, Forge, Stock
- Just installed GSC 272's 10.5 hotside ebay o2
- speed source 2 piece under hood bushings installed tonight
- Thinking of buying a TME Turbo.
- Broke my cam gears...argh!
- 9.8 --> 10.5 Hotside Question
- Cylinder wall has a 'line' in it..please advise..
- Help me decide which TBE to get.
- Clutch/Flywheel tommorow...37500 miles
- Rear diff question
- help
- Who sells Evo VIII or VII Valve cover?
- 35R, Buschur Stroker, Alchy, and...
- 850 on a 35R ???
- (PICS)nDYNO results are in, I went to DYNO4MANCE today
- Mods with stock ecu program equals lean condition??
- oil filter
- 5th gear grind AGAIN WTF!!!!
- Check out my curve, should I switch to alky?
- Upgrade...Whats next...
- Turbo Elements Intercooler
- GT35R highest boost #'s and what power with methanol cooling the temps...?
- is it necessary?
- Intercooler piping question...
- BLOWN Motor, Part 4 (Bottom End Pics!!!)
- Overheating
- What __cc Injectors should i use?
- ARP Rod Bolt Installation
- Buschur-ported, Swain-coated stock turbo parts
- Flex-a-lite fan installation directions?
- EVO 6 Build up - USA style
- agency power lower motor mount feedback
- megan
- My Buschur Racing GT35R daily driver results
- Can you swap an "MR 6-Speed" tranny in an 03' evo?
- Electrical/buzzing sound from rear of car.
- walbro 255 fuel pump trouble
- another guessing number?!? =P
- upgrade question.....
- Buschur Racing Dyno Tunes New 3065 Turbo Kit
- Lean Bank 1 P 0171??
- Help diagnosing a friends Evo
- P0300 with hks dli2 ignition
- Holinger Site Down?
- whinning in 5th ??
- Anyone ever use this obd2 datalogger
- What causes turbo surge?
- what kind of intercooler pipes?
- Buschur ported and Coated 10.5 Hotside...how much power gain??
- Dp before boost control???
- BR 20G-9 vs. BR GT35R
- 05 Evo AFR
- i know, i know unos
- AWD dyno around Raleigh?
- Will You Replace ConRod Bolts?
- Fuel Pump wide open...
- 9.1 Compression and Timing?
- Blown head gasket..
- Single vs double flapper hotside
- Evo Mechanical Problems?
- Flywheel question
- Buschur SMC kit question
- Why pay $80.00+ for a manual boost controller?
- AEM EMS > piggyback or flash for safety?
- do intakes lose power? do i need a tune? explained
- Boost Problems
- High Picthed Sound on Boost
- question about blowing the head...
- Brokedown, won't start grrrr
- Evo IX gets Flashed @ TopSpeed!!
- Oil too thin, ticking.
- Just Replaced My Clutch
- Question on alk injection
- How Many Evo Owners are Women?
- Noise After BR Stage 2 Install
- 264/280 camshaft and camgears setting
- Is my walbro dying?
- Drilling and tapping stock intake manifold
- Forge Unos MBC Problems
- ATTN: All buschur/SMC alky kit users...
- SBR gt35r installed w/pics *56k warning*
- mbc is screwed
- EVO IX - transfer case problem
- Which is better for the EvoIX: Ecutek or Safc?
- anyone else have this problem???whining noise???
- apr head studs and rod bolts.
- Local auto parts places to buy couplers...
- Broken Transfer Case
- How much boost on pump fuel?
- My MR Bov Backwards?
- Walbro pump failure?
- oil level.
- intake manifold pattern?
- Boost/vac source question
- Sputtering issue solved!
- Better way to get 450 HP
- Another High Horsepower 20G-9 thread from Buschur Racing.
- Another Motor Mount Released, Need Serious Testers
- Got my numbers...
- 500whp on stock drivetrain?
- BLOWN Motor Part 3 (DECISION)
- Need help setting up profec2 to tail wg
- Injector Timing (Phasing) Stuff - Tooners discussion
- Damaged Rear Diff?
- What happened here?
- Help Works vs Buschur Axle Back
- Indexing plugs
- Boost help
- Chaning all fluids need help.
- Has anyone dyno'd there 20g-9s yet?
- stock main bolt torque??
- Need Turbo For Lancer!
- HKS Hi Power Spec-R Ti Exhaust
- Alternative Fuels in the Evo anyone???
- AEM EMS question
- XS Engineering 280 Racemax Camshafts
- Arc Intake and Hks BOV kit
- question about dealer checking turbo
- oil cooler thermostat bypass
- BLOWN motor Part 2 (upper end pics)
- **Blue EVO 8's dyno charts for anyone who cares**
- Help!
- Newbie Boost Question
- radiator problem
- Please help! Loud whistle when evo boosting. Not turbo sound
- Boost at RPM 6000??
- Lancer Swap Into Evo
- In chassis piston/rod swap...
- Boost Leak + misfire Symptoms?
- boost problems, help!!!!!!
- cam gear 1 tooth out = how many deg?
- something not right with Greddy TT
- WR? what is it
- Shift Points, Power, and Gearing
- Gains from lower IC pipe on a near-stock evo
- Ways to minimize wheelhop on the EVO??
- radiator
- Clutch....
- horse power freaks system!~?
- HOw come just 2005??
- HEY AL! Look whats inside this thread...( 56K Warning)
- Boost Controller IX - ???
- Aftermarket Air filter replacement
- EBC questions
- SEARCHED: squeaky 2nd gear (lol?)
- Changing IC piping for POWER!?
- What's more impressive? Pump Gas power or Race Gas power
- Pesky P0401 code caused by boost gauge?
- interference (EMI) with EGT
- RVM intercooler pipe kit...
- Turbotrix or dynoflash reflash???
- Buschur Racing Black Car On The Dyno....903whp video
- Why a 3.5 bar map sensor isnt good
- O2 housing
- Boost Gauge rattle/buzz sound?
- logic Perfomance and Buschur lower iC - Race FMIC
- buschur axle back exhaust sound pictures
- evo IX owners w/ turboback!!!!!
- What size turbo does the 50 trim compare to?
