PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Rear diff issue??
  2. spark plug problem
  3. i need some opinions please
  4. Fan no longer coming on. Overheating
  5. Valve seal replacement when I do cams/springs?
  6. IX turbo to 25g Conversion - TurboMikeInc
  7. Need O2 Housing Suggestions
  8. Flow Rate of OEM Water Pump
  9. Replacing water pump
  10. Need input on Kelford 280/280 cams
  11. Clutch Pedal Vibrating?
  12. IX stock boost control, + few mods should = xxx boost?
  13. drivetrain is going :(
  14. intermittent missfire under cruising
  15. o2 dumps vs smaller diameter TBE?
  16. Max TQ on Exedy Twin HD
  17. evap control vent circuit malf need help
  18. FP Red - high psi, low hp - boost leak? wastegate?
  19. GSC S2 cams who is using stock springs?
  20. Intake Noise
  21. ARC exhaust heat shield
  22. AMSoil Ea Oil Filters
  23. boost issue
  24. Evo Turbo in 2002 Mitsubishi Lancer Oz rally
  25. Turbo Diesel Motor Oil?
  26. boost controller question/advice?
  27. HKS blow off valve
  28. Question regarding injectors...
  29. Who here on EvolutionM has the most knowledge about the ACD/AYC system?
  30. Question about Stock BOV location
  31. Oil Leak HELP!
  32. Mine's ACD controller on USDM?
  33. evo dies when clutch is pushed in!!
  34. Exhaust Cam Gear & Kelford 272
  35. UICP and LICP
  36. Hydraulic TOB dd clutches?
  37. AWD Motorsports "BASTARD" EVO.. 1st Stock Frame 700+hp FP BLACK!!!!
  38. help changed spark plugs- now bucking Hard under boost
  39. Ted B's boost leak test how to
  40. Anyone trapping in the 130's with an Exedy twin HD?
  41. buddyclub camshafts..
  42. will hese injectors fit
  43. Overboost after ams intercooler and few mods
  44. possible to bleed lifers without removing cams?
  45. Name that resevoir
  46. Turbocharging. You know what would be awesome?
  47. Chad's XL?
  48. Need your input please
  49. shifter acting funny.
  50. Timing help ASAP
  51. Anyone heard of this manifold??
  52. What injectors are these?? PICS inside
  53. ETS GT3076R Turbo Kit - Ceramic Coated Manifold and Exhaust Housing!
  54. Biggest and Baddest GT4088R Twin Scroll Turbo Kit With 3.5" Downpipe and Reci
  55. HTA3586 Turbo Kit with Red Wastegates and Coated Manifold
  56. Help, having problem with car, thanks
  57. 780cc injectors for around 400whp
  58. FP red intake size
  59. jumpy gas pedal?
  60. Boost Hesitation in turns
  61. Best Break in period for clutch
  62. ACD Tuning Options - USDM CT9As, Read!
  63. installing fp-red
  64. FP Red Boost Creeping at high rpm
  65. A little advice plzz
  66. Where to get head work done?
  67. Does this sound like a correct build??? From a new shop???
  68. Starting off...
  69. remove stock boost solenoid?
  70. Precision 5857 fitment question
  71. titan comp housings
  72. MAPerformance External Dump O2 Install
  73. Can thing by Brake Master Cylinder?
  74. Clutch
  75. Fp Black vs HTA 3582
  76. Hafe manifold and 3076HTA 0.82
  77. Strange humming noise after performance work...
  78. Noob Question prob (SEARCHED)
  79. Where to buy 2 solid, adjustable lifters for dialing in cams?
  80. 73 HTA Green on my early evo
  81. DIY air box
  82. forward facing manifold and keep a/c???
  83. head gasket difference
  84. Tired of the loud Exhaust
  85. CBRD Radiator
  86. Stock turbine housing size
  87. Twinscroll 30r, Single scroll T3 Manifold???
  88. slave cylinder!?
  89. What else do I need for HTA Green?
  90. Car won't create boost, ok 2psi but thats it
  91. Greddy Profec B spec II or Hallman MBC?
  92. idle problem
  93. Oil question
  94. Having some problems
  95. Question for the "experts" about the 2 piece drive shafts offered by various Vendors
  96. changing clutch but....
  97. Another 700+whp build...But this one is mine:)
  98. Which cams to but for my evo 8
  99. David Buschur's RS/BADBISH 2010 build
  100. best intake manifold and cams
  101. Please help clutch problem?
  102. Nisei fmic
  103. Give QuarterMaster a 2nd chance?
  104. Ignition question
  105. what sort of gains will i get with a 2.3 stroker?
  106. tomei rod binding?
  107. Can I make 450?
  108. tomei rods clearence problem!!!
  109. evo 9 drivetrain question
  110. AWD Motorsports T3 Manifold
  111. Turbo leak
  112. Rebuild engine!low oil pressure!!!help
  113. oil seal...
  114. Odd boost tapering...
  115. AEM EUGO or INNOVATE LC-1?
  116. To short shift or not to short shift.. That is the question
  117. Benefits of cam gear on Evo IX
  118. I Reached my Goal! Next is the build!
  119. Can the QM hydraulic bearing work with ACT HDSS?
  120. running on 3 cylinders? rough idle.
  121. CRITICAL! help me! problem with new turbo.
  122. 2.0L 35R Question!
  123. BR double pumper video, facts and information
  124. slippage
  125. clunking and pulling hard to the left...?
  126. problem after accident
  127. Forge RS BOV Stuck Open?
  128. Ignition questions, spark plugs, etc
  129. Slight exhaust/turbo problem
  130. Twinscroll Update - Sierra Sierra Time attack Evo + Philthy's 2.3L twinscroll 4088R (
  131. YR Advance Titanium Exhaust
  132. Transmission Problem?
  133. HTA green or red... i cant decide!!
  134. Fp black or ETS kit
  135. problem with turbo
  136. Cold start issue
  137. Does Boost Blow the motor?
  138. Fuel Pump Relay
  139. Water temps (stock sized rad vs mini)
  140. oil cooler evo8
  141. fp green upgrade/rebuild possible???
  142. car wont go into gear, wtf
  143. Bored With Two Turbos
  144. cam specs
  145. 2.2L 4G63 VS 2.2L 4G64 Long Rod
  146. whinning noise???
  147. Slow boy 2.4 questions
  148. ss water lines?
  149. p0120 code
  150. Turbosmart e-boost street for 2010
  151. evo 8 built motor question
  152. Misfire cylinder 1/injector fault cylinder 1?
  153. HKS Rods
  154. Anybody elses DP sit 1/4 away from the differential
  155. Length of the cat?
  156. Magnus Engine Build
  157. Top mount turbo manifold
  158. Kelford 272 idle and drivability
  159. Help me I.D this Turbo. Pics and Dimensions Inside
  160. ETS LICP or COP - Which should I buy?
  161. Twin Disk: Quarter vs Competition
  162. New Clutch time...
  163. Car missfiring Plug wire ohm reading
  164. HDI Intercooler
  165. intercooler comparison test
  166. Just Got My New Rear Diff...
  167. Go 2.2 or 2.3?
  168. Compressor wheel pictures wanted
  169. Clutchmasters fx300 or fx400 Input
  170. Hurry help plz! Stalling problem!
  171. Which HID kit do you use?
  172. Is it ok to install stock Intake Mani w/out support bracket?
  173. Salvaged 03 evo with Mivec?
  174. Another coolant issue.. Please help
  175. AEM EMS Series 2 testing and video
  176. Nissan Versa battery?
  177. need help with walbro fuel pump
  178. Competition Clutch Stage 2 Carbon Kevlar Clutch Input
  179. Sputter/Jerking motion upon Boost build up...?
  180. Ti-C muffler on Trust Ti piping?
  181. speed density help!
  182. What kind of bolts for ACT pressure plate?
  183. Neonglh's new project - 2006 IX RS drag car, "Lana"
  184. Spoolin up coils with aem...
  185. Transfer case??
  186. cbrd fmic 3.8in and cbrd mini rad installed
  187. Heater does not feel hot.
  188. trouble controling boost.
  189. which cam goes where
  190. MAPerformance Cylinder Head
  191. Timing advance and rough idle at high altitude
  192. Carbonetics tripple carbon clutch!
  193. How strong is the stock VCU?
  194. o2 housing problem, please help...
  195. installed boost controller, weird thing happening, need help
  196. HKS vs Exedy twin disks
  197. USDM Evo 8/9 and the JDM 8/9 RS
  198. evo 8 gsc s2 274/274 video
  199. Looking for a fitting...
  200. Breaking up/Jerking & other problems
  201. groden rods or tuff rods
  202. Cdi cop sparkplug gaps?
  203. ams/ross pistons?
  204. starter problem?
  205. first gear whine
  206. Green to Green hta73? help
  207. greddy intercooler
  208. Clearances for built engine
  209. AWD Motorsports sets the FP Black Record!!! 691whp / 606tq on Stock ECU / MAF!!!!
  210. Have a question about AC condensor
  211. Need some quick helpp!!
  212. radiator fan problem
  213. evo 9 mr questions
  214. o2 questions
  215. what do you think about this??!! evo ix head without mivec
  216. which act disc is better...street or 6 puck?
  217. ACT HDSS good for around what power level
  218. Upper IC pipe size
  219. Highest pump gas evo still running show your stuff
  220. XTD Clutches...
  221. Testing a 50 mm External Wastegate on Evo IX
  222. Help Me Identify This Clutch!
  223. greddy type s bov
  224. Evo 5 Speed 4.11 / 3.73 Final Drive Pros/Cons/Experiences
  225. Tial 50mm Q Recirc? *check this out*
  226. 2.4L 4G64 Built Short block setup, anyone with their Evo 8/9
  227. 6-Speed MR: Test -- Information to Follow
  228. evo ix turbo on evo viii
  229. Thread Sealant on Header Studs
  230. Grinding in first gear
  231. Forge RS installed, flutter flutter flutter
  232. Who is running a Spec Stage 3+ Clutch???
  233. 10.5 hotside, or NOT?
  234. Sad discovery!!
  235. Thicker Gear Fluid to fix Deceleration Noise??
  236. Supra vet, net to EVO
  237. 2- step issue?
  238. 6 spd trans oil seal leak at axle- anyone else?
  239. please help oil return line gasket ?
  240. What do you think? PLZ HELP!
  241. AWD Motorsports Round #2 of Testing with FP BLACK on the " Bastard " EVO!!!!
  242. 4G63 block adapter issue
  243. Looking for opinions and feedback. BBK or SST
  244. Driven Innovations Inlet
  245. Fidanza Flywheel Review
  246. ARP headstud question
  247. Upgraded Valvetrain
  248. Horrible hesitation
  249. 2.3 with fp red OR 2.3 with FP black
  250. 6 speed clutch
