PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 [216] 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Boost Taper
  2. APEX I induction box and power filter installed...
  3. Upper Intercooler Pipe
  4. MR 6sp Short Shifter
  5. Greddy Turbo Upgrade...
  6. 05 evo shifting problems in 2nd and 3rd
  7. Anyone install a JDM Front LSD?
  8. Ok.... What's NEXT? MODS
  9. Need this part!
  10. How to tell fuel pumps apart??
  11. Logging with AEM Gauge-Type Wideband UEGO Controller?
  12. transfer case and diff fluid change
  13. how often?
  14. Not holding boost with EVC V
  15. Tranny drain plug is hosed
  16. Downpipe question
  17. Stock Cams
  18. AMS downpipe and Lower IC pipe installed
  19. OMG the work throttle body is the SH$t!!
  20. who makes a good intake manifold
  21. What injector size???
  22. Which testpipe works with the stock catback?
  23. MR BOV restore my boost
  24. Best Mail-in ECU Flash
  25. Megan Racing DP on eBay...
  26. is anybody here running a unit chip piggyback system?
  27. What is the best Intake Manifold? BJ's,magnus etc?
  28. Questions....Just Installed 272 cams
  29. EVO Tranny
  30. HKS RS Intake and oil on the filter?
  31. Help!!! How do i fix this.
  32. RC engineering saturated high impedence injectors
  33. Tuning in CO
  34. stock evo
  35. Turbo Back Exhaust Gave Me Fuel Cut???
  36. Act Clutch!! Help Please
  37. clutch fluid restrictor in the 05 evos?
  38. Removal of oil squirters
  39. BOV Masters READ!!
  40. Evo VI dyno results
  41. can u guys esteimate this ! ?
  42. sheet metal intake review????
  43. I need a new clutch!!!
  44. Stupid check engine light-
  45. HKS GT2835 or AMS GT3071R Turbo Kit
  46. Engine parts strengthening ?
  47. Help With Cam Install!!!!!!
  48. Defi D boost gauge reads high?
  49. best setting for cam gears
  50. Is my T-case screwed???
  51. dsm tranny
  52. Oil Temp Sender Drain Plug Question
  53. Differences in cost.....
  54. buscher tbe and cel
  55. Problem from shifting from 1st-2nd almost gone!
  56. Jimmy's RnR Built EVO
  57. Buschur turbo 580 compared to others
  58. Getting into the 12's
  59. CAM question
  60. Wastegate vs. Blow-Off Valve
  61. Blitz SBC id3/MAP Analyzer
  62. greddy turbo timer
  63. How is Injen IC pipe and INtake?
  64. are adjustable cam gears actually needed?
  65. A/C hose removal
  66. balancer shaft elimination????
  67. BLITZ Induction Cover
  68. EVO Durability
  69. DSM parts in EVO
  70. MR Oil filter.... is it different??
  71. Limits of stock MAF/ECU
  72. hks r-intercooler and injen intake
  73. Best Short Shifter
  74. what kind of bov is this
  75. what to do for 2wd dyno
  76. Cheapest Place to Buy Stock Flywheel
  77. best choice intercooler for stock turbo
  78. Help with T-Bolt Clamps
  79. Broke Bolt trying to install O2 Housing! HELP
  80. 2005 Evolution ECU and Greddy Turbo Timer problems...
  81. Got "SERVICE ENGINE SOON" light
  82. CEL On after random stall??
  83. Evo throttle electronic or cable-linked?
  84. FMIC & Turbo back exhaust make huge difference....
  85. does anyone know why???
  86. spark plugs
  87. Problem removing TC from trany
  88. Rvm Lancer Evo Viii Camshafts 264
  89. Solid vs. Lash type cams
  90. Loud Thud Shakes car...Detonation?
  91. My car wants to Move in Neutral??
  92. 1psi and 1mph gain from 1g DSM bov
  93. Cams
  94. Any Profec Type S users....
  95. Random Tech Cat
  96. How do you tighten Weapon R Engine Torque Dampener??
  97. GAUGES ? help
  98. Just installed Blitz ebc -- need help w/a couple issues
  99. Go figure Tranny Problems and P0300.
  100. Parts for Stroker kit
  101. Boost Leak or Something (HELP!)
  102. tranny whine yay. Help please!
  103. remote oil filter?
  104. Dyno sheet on MR with flash - BIG improvements
  105. Need Vendor help about exhausts...
  106. anybody w/ service manual
  107. Helix Dp rant
  108. Is this a typical gain for gears on stock cams? (dyno plot inside)
  109. Bogging after installation of Blow-off valve
  110. Going to buy N-tercoler + maybe reg nitrous kit.
  111. question about 05+ EVO downpipe
  112. Differences between 03 / 04 Ecu and the new '05 ecu
  113. Turbo surge w/Turbo Smart BOV
  114. Dynoed apex turbo kit
  115. Engine Oil Residue on the two trailing arms
  116. Gauging interest in shorter 5th gear
  117. Mr Bov stalling your car? x brand, sucks? Try APS
  118. head bolts? head studs?
  119. Turbo trix flash with safc
  120. Precision Turbo&Engine dealers in Portland?
  121. Helix DP question
  122. AMS vs RNR
  123. Boost Too High On Avcr
  124. $175 for Manifold and O2 Housing!!!
  125. Bushur or Helix TBE?
  126. Question on the Boost Pills
  127. tarmac/gravel/snow
  128. Help Car Stalling
  129. MR clutch?
  130. Dealer quote of $1,800 for new clutch install
  131. Stock throttle body size?
  132. Greddy Type S on EVO8
  133. Question on Cam angle sensor
  134. Those with MBC ???
  135. Tapping my EGT into my O2 housing, people who have done it...help
  136. 6-speed tranny on eBay
  137. Which UICP will fit??
  138. Still won't go into gear!
  139. USDM exhaust fit on JDM's?
  140. MAx psi on Greddy Type S
  141. Evo MR
  142. hessitation at 6000rpm and up
  143. part number for colder plugs...
  144. 4g63t query
  145. evo 7 power fc to evo 8. please read.
  146. P0300 Code
  147. Made my own UICP pipe
  148. P0300 Poll
  149. Evo Viii Vs. Wrx Sti
  150. Max boost for MR
  151. What is wrong with my EVO? HELP!!
  152. ? Installing HKS 264 Cams
  153. PTE vs Spearco cores?
  154. Is the Stock EVo turbo upgradeable?
  155. MR Turbo (10.5) $1600
  156. Flywheels - Resurface Stock, New Stock or Aftermarket One?
  157. JIC vs GREDDY!!!!!!!!!!!!!
  158. Drove an STi and my Evo has a problem??
  159. opinons on twindisc clutches
  160. Question for those w/ Boost control
  161. Please, help for turbo choice...
  162. Exhaust question
  163. More power for 2003 evo
  164. Evo engine into a rear drive car..
  165. installed new clutch won't go n2 gear
  166. New Buschur FMIC
  167. Xede question
  168. Helix 3" Exhaust, Cat, DP Review
  169. puddle of water underneath car
  170. HELP Please P0420 code,Catalyst Efficency Below Threshold
  171. Gruppe-S online packages?
  172. Anybody thought of using dynomat to quiet the tranny?
  173. Forgemotorsport Tbe
  174. RMR 6 puck plate compability with Exedy hyper single clutch
  175. Just got dyno n tune something seems wrong
  176. Whinning noise?
  177. HKS RS and Aftermarket Tubokit
  178. upper radiator hose size?
  179. Quick question on GFB bov
  180. MY EVO is loud.....HELP
  181. profec b II help
  182. Fuel Stabilizer
  183. Which way EVO engine rotate?
  184. MR valve ... plastic?
  185. Which cat delete
  186. porting the intake manifold on an evo?
  187. Greddy Type-S (Pruven Performance)
  188. " ENGINE SERVICE LIGHT HELP PLEASE"
  189. Need Help Please
  190. Price of Stock BOV
  191. Buschur manifold question
  192. log knock with profect e-o1?
  193. Hi !! Plz Help Me To Answer This Question
  194. revolver or hks 272 cams?
  195. DP with or without Flex Section?
  196. Manual Boost Controller
  197. what is boost spike?help?
  198. B&B exhaust
  199. For Those With Helix Exhaust...
  200. Turbo Questions!!!
  201. buschur flash
  202. Apexi Turbo Timer O2 Question ? PICTURES inside
  203. Comparing the 5 speed EVO trans to the 6 speed MR trans
  204. Evo 7 & 8 front bumper & hood
  205. MBC setups
  206. Does HKS make valve spings and/or titanum retainers to fit w/HKS cams?
  207. Which turbo kit to get for 400 HP ????
  208. Anyone have the Revolver cam kit???
  209. clarify for me please! =]
  210. Evo VII Body Kit
  211. Test Pipe + Heat shield in one
  212. how good is RnR Racing
  213. RPM raise between shifts
  214. RPM raise between shifts
  215. to those with cams please read
  216. turbo upgrade
  217. stock boost questions
  218. Stroker+GT35R
  219. Evo 7 or Evo 8 body style?
  220. Brake Dust
  221. 5spd or 6spd?
  222. Favorite EVO color
  223. APEXi N1 CATBACK
  224. HELP: Transmission humming...
  225. Which nitrous and Cryo kit are the best?
  226. Timing and tuning
  227. T-4 Turbos?
  228. emissions question
  229. has ANYBODY had any problems with a turbo trix flash
  230. Emissions Testing and De-Catting
  231. To restrictor or not restrictor with aftermarket Clutch??
  232. Mitsu factory overbores?
  233. Question for MARTIN MUSIAL
  234. Monster Turbos...what for?
  235. 5Zigen Pro Racer A-Spec Exhaust
  236. p0400 code
  237. how loud is detonation?
  238. Flapper in stock exhaust?
  239. BJ Intake Manifold
  240. Looking for a broken t-case with a good ring and pinion
  241. Why does my Helix TB only rattle in the rain?
  242. Return Fuel Line System
  243. Hks Evc V Boost Controller
  244. T-3 Turbo Mod???
  245. Some pics of my hard work today
  246. 05 Evo (And MR) compressor cover vs 03 compressor cover
  247. Help me decide on exhaust... Buschur or vishnu?
  248. Water Temp sensor mounting?
  249. evo feels week
  250. PICs of Detonated Head
