- safe rev limit on upgraded valvetrain
- how much
- !!!help!!! car won't go into gear
- Prosportgauges.com?
- Damn You Turbo Compressor Nipple Hose!!!
- recommend me some cams
- Reviews on Blitz Catback? N looking for Used?
- transmision transfer case and rear diff fluid?
- Help me choose GSC S2 or Cosi Mivec cams?
- How much blow much be there in a built 2.0L
- outrageously priced parts....vent yourself to the atm in this thread!
- Built Motor Questions
- gain w/ injectors?
- Down Pipe
- O2 housing question
- Downpipe rattle
- Is my stock 8 BOV leaking??? Please help!!!
- Confusion with Boost Leak = Turbo working harder?[I think I answered my own question]
- Tomei EvoIX Cams??
- GSC S1 CAMS stock?
- 115 oct w/ 93oct map
- EGT probe thread size
- Twin scroll turbo kit.
- need help: will the intercooler + piping
- Anybody have pictures of a ported megan manifold.
- Need help with rear diff
- Picture of Megan header under WOT
- Best Method to Reach Turbo/Waste Gate
- Actuator arm preload f/ EvoGreen
- Question about Boost Leak via Diverter Valve
- Muffler Size
- TB Coolant Bypass Mod - WARNING
- My ported exhaust manifold and O2 housing
- *****important Notice For The Forge Diverter Valve*****
- 9 sec. What gear box is this?
- AGP FMIC & Nisei LICP Pics, Testing, & Review
- Odd shifter problem
- 9 in 8
- What boost to run after tune?
- Installed Walbro, injectors, 02 housing...lumpy idle??
- Who here has done a mail in flash for a gt35r and supporting mods? Thanks.
- Gt35r???
- Tilotn rebuild PN???
- how to change the rod bolts?
- waste gaste q's
- 880cc vs 1000cc injectors for e85?
- Extreme Turbo Systems and English Racing hit 9.7 and 145mph
- How good are rebuilt engines?
- Manifold swap..
- Is anyone using XTD clutch
- And you say you don't need a Catch Can?
- Boost Numbers???
- ebay Coil on Plug ignition setup?
- Can't boost past 12psi. I give up!
- where to buy a transmission
- Redline trans fluid
- Aout to install my new Buschur 35r today!!
- O2 sensor ??
- HELP!!!!! With my IX
- Help with Injector Duty Cycle
- Weird sputter... am I "blowing out spark" Need Advice
- Ordered some WORKS goodies :)
- Approx. HP with IC setup?
- what is this?
- ebay/xs power cooler
- Should I step up to bigger cams?
- Need Manual Boost Controler Help!
- AMS GT30R (3076) or 50 Trim for a pump gas street EVO?
- 44mm Tial Wastegate not working
- Ported intake manifold
- cosworth cams valve tick?
- boost problem
- ACT HDSS/Stock Flywheel
- Going rate for a clutch job....
- Turbo
- Evo Green Dyno Sheet on 05 Evo with minimal mods
- Stage II Evo IX - Buschur Parts - dyno sheet
- bent LICP outlet....worth fixing????
- AMS FMIC Fitment?
- ARP Rod Studs
- Is it ok to extend o2 sensor wires?
- ETS 35R kit makes 545hp 480tq pump/meth MD dyno
- Stock Evo IX BOV
- Whats the difference between GSR (w & w/o ACD) and RS transferee cases?
- AMS HFC VS Resonator pipe ??
- as it stands now... smoother boost curve
- Injen Intake/Flutter
- Very strange noise?
- CEL after cosworth cam install???Help
- AMS Performance or Buschur Racing?
- EGT Gauge install in AMS (or other header-based) turbo-kit
- LC-1 Power On Help
- Aftermarket FMIC help even with alchy?
- P0456 code.
- Wrong Tune!!
- Good IC Setup?
- MBC vs EBC...
- my evo overheating :/
- 6 puck carbon clutch is there anyone that makes one
- Burshur DP Question
- FPgreen on stock internals safe?
- Backfire question
- injector tick or somthing else?
- exhaust size?
- MAF Sensor delete
- Gt35R 2.3L Evo 8 with AEM - dyno sheet
- gsc s2 cams in a ix
- Injen intake vs. stock box vs. ic pipes
- New Evo green set-up
- going fast with a none acd car...
- stock exhaust mani. VS. megan
- New Turbo
- what's the + & - of the 6 speed MR trans?
- Cant find German Castrol oil anymore?!
- Anyone using Helix cams?
- Help with a 2.4 block
- How much boost
- Spun Rod Bearing Question
- Magnaflow TBE vs. Buschur TBE with Magnaflow Muffler
- New Tbe> How Loud???
- Serpentine belt lenght Help!
- Starter replacement
- How important is bleeding lifters when cam installing
- Rebuild on T/C average price?
- Help please. Oil plug thread.
- from full-race kit to stock... pictures
- Odd Engine Noise at 5500rpm, any ideas?
- Need Help on my 03 evo 8
- Just ordered my 42r need some input!
- Fuel hose cracked and leaking ?
- Recognize This Header??
- Smoke from center console
- faint smell of gas at WOT???
- I think I broke my front Diff???
- Need Clutch ASAP.
- Where can I buy an anti surge compressor housing for a gt35r?
- Boosting Issues, Help!!
- timing belt tensioner tool
- stock head studs with 35r and meth??
- no start ?
- Me and My Tilton love hate relationship
- Spearco W.A.V.E. Intercooler?
- Need Help – tcase or tranny issue?
- Blown Engine, Change the Oil Cooler?
- MBC Problem
- injen intake w/ upper and lower ic piping
- ARC Parts?
- best stroker kit and cheapest
- questions on qtp downpipe
- 280's stock pistons? Does it work?
- dynograph and knock
- vacuum problem!
- Ideal camgear settings for HKS 280's/AMS 50 Trim???
- Where to get porting done in stamford connecticutt.
- i hope this is the right section...
- Turbo rebuild kit
- ebay exhaust
- Gear shifting problem...Please help me diagnose
- 880 cc injector question
- upgrading EVO 8 valvesprings and retainers w/o removing head?
- stock block power?
- Greddy Upper IC pipe Question
- Interesting weekend of IX dyno results - cosworth cams vs. no cams
- what hp do you think ill put down????
- Full race not port matched?????
- cylinder head specs and repair...got questions
- Will the hks racing suction intake work with a atp gt35r kit.
- Quick Time Performance Downpipe w/ E-Cutout
- Listening for Det
- Hallman Boost Controller Q&A...
- Bad lifter, Rod Knock, or Bent Valve (Video)
- GSC Camshafts, Mail in Flash ??
- quick question about wastegate install!
- Boost problem (been searching for answer for days now)
- Looking for strongest rods
- Heet
- New turbo kit.
- question for anyone that has done ix cams...
- Cams, Fuel Pump, Afr???
- Whining Sound, Not sure if it's the Transfer Case
- t.r.e tranny grinds with 2k miles????
- My Dynojet sheet
- Hks Blow off
- wastegate damage @17psi
- Timing belt problem
- Problems with idle and cutting out
- Thrown a rod out the block!!!
- Turbo upgrade and AIR/FUELS??
- Questions regarding greddy T67/25G
- blitz i color boost controler v.s. zeitronix wideband.
- Lower Degree Thermostat
- Intakes that work with Apex'i intake box?
- new numbers
- 13 psi:(
- over heating. HELP!!!
- Running 264/272 cams without tuning
- Stock Intake Manifold Question..
- WTB? Tired of ACT
- super rich
- Greddy Ti-R and UR testpipe =OMG LOUD
- JunB.L w/ Perrin 3" DP Vs. Buschur 3" TBE
- Question about alky over cams
- What Downpipe Should I Get With JunB.L?
- 20glt but what else
- Is their a ebc that reads a/f, boost, and other vitals. like a wideband?
- Zeitronix user opinions
- Need Help Installing Injen Licp On Evo Ix
- cusco/exedy?
- Honestly heads studs or not
- What is the max boost I could run safely with my gt35r kit, with 93.
- Noise while in gear at idle
- Life of a built 2.0L Block
- EXHAUST FOR MILD TUNING,,tubular or standard ?
- Prosport EGT guage....slow responding???
- 4G63 Oil life
- Friggin Silencer stuck in Muffler!
- Leakage help please
- Injectors for Evo Green & 550bhp
- Tob Hell!!!!!!!!help!!!!!!!!!!
- Gear Shift
- 5-speed vs. 6-speed
- Catless or High Flow Cat?
- safe without a tune for 1 month?
- 10sec Recipe?
- Chime in if you ever had your tranny filled with diaqueen.
- What is a good performing intercooler?
- Ideas welcome... P0300, P0139
- Boost Level question...
- Experance with Brad Penn Motor Oil
- Evo ix gain downpipe only?
- 20G-LT / FPGreen boost and IDC data
- Help !!! New Turbo Mods for My Evo III
- Help!!!
- Clutch Pedal Adjustment Questions....please advise
- BOV sound??
- JDM evo 9 LSD, will it work?
- New Clutch for MR
- Possible causes...
- acd fault codes
- Oil pressure/EGT guage install HELP!!
- Car overheating Slightly!
- Downpipe Fitment Problems
- Clicking noise in the front end
- ses light ??? please help (NOT A NEWB??)
- RPS carbon clutch
- 2nd gear lock out.
- FP3065 On A Budget??
- Some Give Back From the Big Tuners Please.
- wanting to put on my new FMIC.. BUT....
