PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 [198] 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. exhaust
  2. Tuning Limitations and Options?
  3. Blown Gasket! Picture
  4. hallman mbc modding
  5. Dynojet AWD Dynomometer
  6. What is this for???
  7. Vacuum reading for Greddy boost gauge
  8. 2 stroke or not 2 stroke
  9. Cat Delete or resonator? and exhaust questions
  10. Unusual brake and voltage cell flashing! Please advise...
  11. Some thoughts on the TOB rattle
  12. Helix Exhaust, DP, Test Pipe
  13. ok, installed mbc and intake but..
  14. evo 8 intake manifold on a dsm head???
  15. A/c Broke!!
  16. White Rabbit update
  17. Cusco twin metallic clutch....ADVICE NEEDED
  18. greddy type s question
  19. ANYONE EVER blown a hole through your Transfer case??
  20. Need some help
  21. 14b vs 16g
  22. Forge Evo Valve Fluttering
  23. Alchohol injection and GT35R
  24. FS: Stock Exhaust
  25. my coolant tank was empty
  26. Fuel Pump Problems???????
  27. whats with the weird noise on my evo?
  28. Toluene/xylene injection............
  29. Broke my t-case while installing clutch
  30. Looking for info on ILSAC ratings for motor oil
  31. Transmission Problems
  32. review for RNR turbo outlet and performance coatings
  33. Flywheel - evo = 97 GSX?
  34. Time frame for trany and tc to be done?
  35. ACT and tranny problems
  36. Is this normal or do I have a serious problem???
  37. Any Oil Catch Cans That Fit?
  38. leaking boost???
  39. What is this?
  40. should i be worried???
  41. Bearing Cap Removal
  42. Shifter Bushing Question
  43. relocating bov with i/c pipe
  44. New EVO owner/vendor checking in!
  45. Question for you alky users.....
  46. P0234 - Guys with little/no boost tapering
  47. Coolant bypass on throttle body?
  48. APS Exhaust?
  49. What a diference!
  50. WTB: Apexi or TurboSmart Boost Controller
  51. defi d boost gauge question
  52. alchy/water/ww with no boost increase
  53. Intercooler Piping Kits
  54. help
  55. im peaking at 17.3PSI.. WTF?
  56. threw a cel today, P0102 need a little input on it
  57. HKS Carbon TI Fastening Flange
  58. Nitrous Jets?
  59. personal exhaust reviews needed for GREDDY, TANABE, FUJITSUBO, AMS
  60. car making funny noises
  61. -64 Degree Timing
  62. Intake proble?
  63. halman mbc question..
  64. best price for off the shelf Garret turbos?
  65. What Alky kit better
  66. Car Won't Start
  67. stock air box w/ stock filter Vs. K&N cone filter
  68. help with type-rs bov setup
  69. best cam setup
  70. Bleeding the acd?
  71. ClutchNet anyone?
  72. Electric Super Charger???
  73. Precision Shaft Technologies
  74. ACT Man, need your help!!
  75. RPS max series spring hub
  76. What is the "lift" on the stock intakr cam as opposed to the HKS/GSC 264 intake cam?
  77. ACT Xtreme Torgue rating???
  78. what to do if i drop a 18G or 20G turbo
  79. Holy loss of torque
  80. Vendors: Looking for Autronic 500r, M&W Pro14, or Motec Cdi-4
  81. I want my car to go faster! HELP
  82. Bad Shifting prob in Evo
  83. ACT clutches.
  84. Boost on race gas??
  85. Gt35r, Gt40, *gt37*???
  86. downpipe gasket help
  87. Want car to go faster! HELP
  88. Anyone have Aftermarket lifters?
  89. SS clutch line and restrictor?
  90. Exhaust
  91. Upper IC Blowing off under boost
  92. weird stuff happening ????
  93. bad wheel hop...
  94. stock cams with custom grind
  95. How come there is no talk about the HKS 280 Cams?
  96. Whats a good plug gap to run with the HKS DLI1 twin power???
  97. Apexi induction box bracket help
  98. Over filling oil
  99. ARP Headstud Break-in?
  100. Anyone else's Exedy disengaging?
  101. Best Stroker kit?
  102. strange clutch sound
  103. Lucas Gear Oil In Transfer Case?
  104. roasted clutch? please, join me
  105. Megan Racing Exhaust & Kartboy Hangers
  106. Need Help ASAP
  107. Harman Test and Tune Results
  108. JUN cams anyone?
  109. How much power to expect from IC?
  110. How long before OEM clutch is broken in?
  111. Gruppe-S Stage 1 ECUtek Dyno Result!!!
  112. Stiff clutches
  113. opinions on presicion SC6152E
  114. Check Engine Light - please help
  115. Stock clutch differences
  116. AFR w/ 50% v/v MeOh/H2O
  117. Clutch adjusted, now clutch is slipping
  118. AVO exhaust
  119. Pressure drop during test = leak?
  120. Fitting 2.5" O2 housing w/ 2.75" DP?
  121. Need a Clutch "HELP"
  122. Help Getting Heat out of the Clutch
  123. Stopped boost tapering, but now P0234 keeps showing up
  124. Scan tool,Dyno tool,Datalogger i guess?
  125. the search continues, please help!
  126. HKS Racing BOV Type II
  127. differance between ssautochrome and megan..
  128. Considering the Tilton Clutch upgrade for my 05 EVO 8
  129. my head is spinning....
  130. Has anyone purchased any of these from RnR Racing?
  131. The Cons with a flex section on a Down Pipe
  132. What whp and wtq should this bring?
  133. My name is Kevin, and I have an alcohol problem!
  134. Weird Noise!
  135. My car is making a *thud* *thud* *thud* sound... is it my ACT clutch?
  136. Cam decision?
  137. Megan Downpipe Question
  138. fuel pump 12V wire... how to add one?
  139. Problem starting car after header install
  140. another SES question
  141. Ported and Polished Turbo Pieces
  142. westech performance group
  143. Transmission Problems HELP
  144. Modded gt35r...
  145. CHECK THIS OUT...AWD Mustang Dyno in and running at Buschur Racing
  146. Is this normal?
  147. Flywheel Resurfaced?
  148. Best intake
  149. Name That Noise Ver. 2.0
  150. DC sports turbo manifold
  151. Those with 264's
  152. Creader: Good or bad? (p0300 studdering issue)
  153. AEM EMS fix p0300?
  154. how do you get rid of code p0171
  155. Experiances with Ultimate-racing Highflow Cat
  156. White Rabbit Deals Another 400 Whp Dyno
  157. Genesis/Derive engine?
  158. Tapping noise after cam install
  159. BOV question
  160. Odyssey 680 battery died on me
  161. boostcontroller.com and buschurracing.com
  162. halman MBC question..
  163. Car Died 2 Times, in 2 Track days... Help please =)
  164. Why do performance cams make the car more prone to stalling?
  165. BOV Sound Sites
  166. Nitrious intercooler sprayer
  167. New Buschur Lower IC Pipe
  168. Transfer Case Oil
  169. Stock Intercooler dimension size
  170. boost trouble
  171. 04 evo redline/fuel cut off
  172. Low boost
  173. Best Turbo Set Up for Pump Gas and Alky?
  174. for people who suddenly experincing boost tapering
  175. Nisei Mini Battery
  176. So My Turbo Blew Up...
  177. spark plugs decision
  178. Whine when engaging 1st gear?
  179. P0234 - how does the ecu sense the car is overboosting??
  180. How much boost can the stock ignition take?
  181. Shifter Question
  182. P0300 -> 2 days later -> Bad coil
  183. EVO 9 piston rings
  184. Ralliart vs Works Drop In
  185. turboxs insert ????
  186. JDM fuel injector identifiaction?
  187. oem blow off valve problem.
  188. How much faster will i spool with nitrous?
  189. what kind of damage do I look for at 26 psi?
  190. This is what happens when your T belt Slips
  191. someone help please
  192. HELP...Mis-firing...
  193. Throwout bearing/ Install Help
  194. best front mount intercooler?
  195. Clutch adjustment question
  196. Opinions on what to do next?
  197. Name that noise...
  198. Induction box
  199. The end all discussion of cam gear
  200. Anyone Dynoflashed for an intake then return to the stock one?
  201. Stock Turbo Outlet Elbow Nipple
  202. clutch pedal adjustment question
  203. stock bov
  204. 2.4 motor help
  205. will AC on spool turbo faster?
  206. Question for people with buschur upper ic piping and 1g bov
  207. AFR when tuning???
  208. Helical gear LSD?
  209. RPM drops every 3 seconds... what could be wrong?
  210. Any way to distinguish duration on GSC cams?
  211. help me out guys; exedy 2C v. ats 3C
  212. Bad boost gauge or a bigger problem?
  213. ***power Q**
  214. To beat a dead horse, Is my TC bad?
  215. Where to get the 10.5 housing (from Switzerland)?
  216. Clutch peddle dead. Low brake fluid. couple questions
  217. Greddy R-Spec Intercooler
  218. maf honeycomb
  219. exedy twin converted to triple????
  220. Whining Noise
  221. few questions about stroker kit
  222. Check out my NEW upper IC pipes !!56k beware pics are big!!
  223. the 280 hks cams are in
  224. cams
  225. Tial BOV Psi holding capacity?
  226. Fidanza Cam Gear bolt size?
  227. HELP: Missing bolt on exhaust hanger BR Muffler
  228. The Tanabe downpipe
  229. ic pipes
  230. Turbo Timer Problems...Help!
  231. Benefit of cam gears?
  232. whine-like noise from engine
  233. FS: Helix O2 housing, new, still in box
  234. Anyone have the Reverse idler TSB??
  235. cat back exhaust
  236. Low compression #'s
  237. Stock idle
  238. White Rabbit Real Deal 415awhp
  239. Transmission Rattle
  240. HKS 150 cell Cat
  241. Greddy Typs S bov = 95 Eclipse kit?
  242. Rnr o2 compared to megan
  243. Spec Stage 2 Clutch/Flywheel
  244. need injectors for alky?
  245. UR uicp install problem
  246. Pics of my new EVO 8 exhaust set-up
  247. MBC Install How TO Help
  248. WHP gains on HKS 272S straight
  249. External Wastegate Question
  250. downpipe
