- where can i get valve keepers? need help asap! please
- Transfer case
- Wierd Noise above 60mph, Any idead?
- AWD Motorsports Turbo Manifold Hotness.. Out The Front!!!!
- bought 10w-40 by accident. question.
- LOUD WHISTLE...real bad...
- Q's about Evo 9 and 8 Stock Turbo
- Which BOV is better?
- help please breaking up in boost
- Need help deciphering evo 9 cam brand...
- Head gasket change during springs, retainers, and cam install.
- Clutch Question
- Hallman MBC help
- junk buschur mini battery where can i buy another?
- FP evo green Hot side question.....???
- Shaft seal install problems?
- Muffler delete
- QTP downpipe and o2 dump
- Get Gas, car wont start, WHY?
- How much power can timing get you? went to the dyno to find out!
- Another Stock Turbo E-85 Warrior.. +38whp/+53tq!!!
- nisei intercooler pipes
- Broke a stud...HELP!
- Need your assitance ASAP, MBC
- uh oh! o2 housing different size than DP??
- look at my GM MAF, i have a question
- SMC Water Injection Help
- EGR and Overboost codes?
- installed BR filter kit, did i gain hp?
- Fidanza 3.2 vs TTP ACT 6 puck
- timing belt tensioner stripped
- br piping on a turbo xs intercooler?
- 700 awhp/565 Trq.. HTA35r Strikes again!!
- Critique my car, 12.00 @ 119, 35r pump/meth
- Zaklee Cam Cover
- Boost Gauge Randomly Reading Wrong PSI
- Evo Red
- Click / Tick ?? Stumped, Advice?
- DC downpipe on my IX mr
- am i crazy or is my gauge broken
- boost leak test causing oil to come out of 02 housing?
- Exedy Hyper Single - MH01SD - HELP!
- Boost leak issue
- Anyone running the new S2's
- help! car problem bad sensor maybe?
- Help me choose Cams!!!
- flowmaster 40's Exhaust
- How long did your OEM clutch last
- Shifting has some kinks in it, normal?
- Is lifting a wheel while cornering hard on xfer case?
- Buschur's RS, first in the 9's on pump and nearly the 8's on race
- Exedy clip problem, and more! Take a look
- rre road tune review
- POS brand new TT just turns off with car?!?!?
- Anyone try the new 80mm comp wheeled GT42 yet???
- Stock Exhaust Mani VS. Others???
- how to adjust a hks eids?
- Spy photos of a new Buschur part
- clutch question
- boost leak test causing oil leak from 02 housing?
- Bov! Ricey Or Not???
- car won't run with brand new sparktech ignition
- fp red vs gt35
- Hallman or Forge MBC
- WORKS exhaust sound clip?
- licp difference
- What size Nord-Locks to pick up for my turbo kit reinstallation?
- will T3 flange manifold fit stock turbo???
- hallman pro rx in cabin
- Golf Ball Size Hole In Rnr Mani
- Cam Question
- Need Help!
- boring cylinders
- front 02 sensor
- 3 ACD lights, only during hard track use
- o2 dump vs aftermarket o2, done yet?
- Rear Diff replacement?
- head removal
- EvoRed Review
- Best Clutch For The Buck
- can CP pistons be reversed?
- Cam Install???? Why so expensive
- Did Kelford send me the wrong cams?
- help me w/ intake install please!
- my stock turbo dyno
- New o2 sensor $300 from the dealership?!!?
- Just threw a P0104 code.
- Oil on manifold...WTF?
- gt4082
- 8 turbo VS 9 turbo
- Cutch Assembly: OEM Throwout Bearing vs. Push Style?
- knock sensor setting SES light
- is any one running on GSC S2 and Stock turbo?
- is this stock turbo?
- Dealer Going under, Help with buying parts!
- hks intake safe w/o tune?
- Transmission problem
- help with engine knock on startup
- 65 vs 90mm TB
- My 2.6L evo 6 just made 623hp/559tq
- Evo just died on highway, fuel pump not pumping
- clutch started to slip, what should i get
- Boost leak, Vac leak, and serious sputtering
- Question about cat and O2..
- Oil Dipstick
- Where can I get a HTA upgrade for my 35r?
- Car sputters, dies out, then won't start...
- Cobb Exhaust Leak found
- Manifold Question
- whats the best set up
- Sputtering with new Clutch install
- Choosing a good piston/rod combo
- 2 injectors with no pulse
- Launching??T CASE??Breakages
- Reichen's EVO 2 breaks the 1000 awhp barrier
- Need to ID an engine!
- 30r????
- Remote ACD resivoir relocation kit
- GSC S2 Idle Video
- Engine sounds....paranoia?
- Upstream O2 Sensor Removal???
- Slow VIII ?'s
- high compression for the evo
- rebuild options for pistons & rods
- Boost leak coming from my 65mm t-body?? Help me fix it!!!
- clutch options???
- What is the best set up for FPGreen ???
- run wont run past 2k rpm..need help and ideas
- Help me find the right exhaust
- triple plate..
- Turbo Noise ETS PT 61 ball bearing
- FP Red, E85, 454hp/408tq @ 26psi
- Evo7 DP and Clutch advice
- Occasional p0300 and "smelly" car...
- MBC - Blitz Boost Controller
- Compression, Idle problems...etc etc.
- Clutch slipping, how long does she have?!?!
- meth and red
- Turboback catless sound level?
- Wastegate problem
- Getting studdering at peak boost
- Need help with finding a 16" drag strip wheel/slick set-up
- SR*S exhaust (ebay) your thoughts please...
- clutch pedal vibrates when not warmed up
- very dumb question
- no start
- Parts Reccomendation
- Fidanza 4.3 Clutch + Flywheel
- injecters ma out ..help plz
- Should I pick a different cam?
- 6765 Precision turbo???
- BOV flutter?
- Acceleration problem..or something?
- Clutch
- P0300 code on a stock Evo, any ideas?
- Montero coils...Anyone interested...
- Cam Choice with Large Turbine
- Question about the quartermaster twin disk
- Anyone deal with SWRacecars?
- need help with cams! installing
- do exhaust mods NEED a tune?
- Compression Numbers.
- R&R Knock Sensor?
- shifter bushings or under hood bushings?
- squeal noise while driving (not tcase)
- quick qeustion about cams.
- Cel P0170
- manual boost controller vs profec b II
- Drivetrain Lagging between Shifts
- Lag between shifts, help!!
- Advice for lowering exhaust sound?
- Replacing the Thermostat Question...
- Did your aftermarket clutch fail?
- throwing DTC P0172: System too Rich
- weapon r intake manifold evo 8
- FP RED - for the road course
- T-3/T-4 set-up
- How much longer for my fp red
- Which downpipe turbo XS MXPor Perrin
- New EVO 9 MR owner - Best Bang for Buck Mods?
- p0300 any clue
- UPS man showed up!
- O2 Sensor
- GM or AEM 3 port boost control solenoid...Stock ECU
- exedy twin clutch spec's helP!
- Trust ti
- ACT HDSS or XTSS?
- Stock cat back restriction
- need help with engine rebuild ?'s
- knocking noise from tranny
- Question??
- greddy type r bov
- When installing aftermarket Cams
- ND Short Wheel Base Longitudinal Engine Sequential Gearbox E9!!!
- Just installed a bunch of new parts
- Mixing E85 with pump gas???
- fp red actuator
- Is 5 gallon portable air tank 135psi max pressure enough for boost leak test?
- Exedy aftermarket clutch
- rattle issues...need advice.
- T4Z 88 HTA or Precision 6765 !?
- axle help
- Need help with ecu code
- something finally broke.. the trans... i need some tips and advice
- Defi BF gauge help
- Test Pipe.
- To METH or NOT to METH that is the Question
- What would you do if a shop did this to your car?
- Phantom knock free reving with Revolver cams on stock ecu
- checking tranny oil????????/
- Cooling Fans Question
- new version of mits dyaqueen for 6 spd
- Can i get a straight answer??
- mod install
- GSC S2 duration
- I need guidance
- I need guidence
- Engine off, key on, press gas pedal and loud noise!
- Losing boost above 10 lbs
- EVO IX HKS build-up lots of pics, needing some advice
- CAI causing drivability problems?
- Need Help Today!!! Swapping Turbos On 2003 And 2006
- Metal shavings
- weird engine hiccup help! plz
- Full Race Clone ??
- Anybody have Ralliart plug wires in stock?
- a few questions about evo mods.
- having some problems with boost
- engine oil light flashing
- injectors needed?
- AWD Motorsports Switching to Haltech E11v2 & Racepak Dash..
- exhaust tip question
- Need help please,down on power -25hp, -50tq after exhaust leak at o2 housing
- need help, what type bolts to get
- Exhaust leak
- Fidanza 3.2, ACT Prolite Flywheel and Stuff - Pics/Review (56k go run and hide)
- What makes engines rev differently???
- Random Misfires Please Help!!!
- Brian crower 280
- Ss Auto Chrome Manifold
- Boost Test Help
- Transmission issues
- tranny problems gear grinding tranny going out....
- changing axle seal on transfer case?
- Evo IX with upgradedcams- Yes or No
- Kelford 264's
- What would this cause? Q For Turbo Pros
- Getting an exedy twin plate clutch...
- 1000cc injectors at 650 help
