PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. O2 Housing suggest? FP Green
  2. Need help! Asap!
  3. MBC problem, help!
  4. best place to get FP red?
  5. porting ?
  6. Heatshield
  7. EVO 9 MR metal BOV or APS hibrid BOV?
  8. Difference between FP Evo Red n "CBRD full BBK" turbo.
  9. please help me find a silencer for a fujitsubo exhaust
  10. A/F ratio after Perrin Intake install
  11. Can you make an EVO RWD?
  12. Stock air box vs Vibrant cone air filter
  13. gt850r build
  14. Question on Megan TBE test pipe.
  15. EVO 9 plug wires
  16. 9k+ rev limit questions?
  17. Stutter at boost
  18. Installed my oil pressure gauge now I have questions.
  19. Cold Day Random Misfire
  20. Cam Gear adjustment
  21. Need help diagnosing a problem!!!
  22. fuel injectors
  23. Ticking sound during acceleration
  24. Help me choose what turbo would be best....
  25. Best BOV/Recircle valve ? Sugest please.
  26. Best Road Race Engine 2.3 or 2.4?
  27. o2 bung on midpipe ok to use for wideband?
  28. Twin BOV intercooler test fitting
  29. Troubleshoot Power - Mods listed, graphs included - I'm told this is not good power??
  30. help with dead cylinder
  31. Flywheel specs?
  32. !!right clutch for the right setup!!
  33. which intercooler piping?
  34. Engine Swap
  35. BBK Full/E85 vs FP_GREEN/C16.. FACTS!
  36. Those with Greddy Intercoolers...
  37. Marks on injectors????
  38. Car is running slooowww
  39. Belt!!!!
  40. Looking for 2.75 Test Pipe
  41. need help just installed injen icp kit now care sputters
  42. Help From Vivid
  43. Better deal: Brand New flywheel or resurface the one i have?
  44. Project Hush (Quietest 3" Exhaust)
  45. whats need for a transfer case rebuild?
  46. Dejon Leak Stop Kit - Impressions?
  47. Exterior or Power !?!
  48. Air bypass Vacuum to Wastegate Acuator, Help! (pics)
  49. I think my Exedy Twin Disc needs a rebuild
  50. Need help ASAP, installing my intercooler right now
  51. 57 P trim hotside for evo?
  52. Sand-like particles in Engine Oil?
  53. Spark plugs for evo 9 ?
  54. Starting issue
  55. Transmission filter change.
  56. return line on AMS FPR kit
  57. Need Help Guys Real Badly!!!
  58. start up
  59. what hard intake pipe?
  60. Walbro Fuel Pump Question
  61. Help me ID this turbo
  62. Cloudy Whiteish Smoke, Burning smell??
  63. Converting clutch: Pull to Push style ?'s
  64. Exhaust Idea/Question - Noob Content
  65. Engine Compression
  66. weird clutch, help!
  67. Be careful when cleaning the throttle body
  68. Where to buy exhaust gaskets?
  69. Advice for 300whp daily driver?
  70. Just a small write up on the ricer
  71. Average price for clutch install
  72. Pistons & Rods for 2.0 Setup?
  73. Question for daily driven HTA35r's
  74. wastegate?
  75. Need some turbo opinions please.
  76. Okada true COP setup???
  77. bov question.
  78. evo 4-8 compressor housing modifications ?
  79. Can this setup make 400whp!
  80. Help:Forge wastegate problem
  81. Engine vibration
  82. backwards recirc valve????
  83. cel
  84. What to do with coolant
  85. oil cooler elimination
  86. shep transfer case ,, which stage
  87. 9 turbo install???
  88. Cams/MIVEC
  89. radiator issues
  90. what brand is better ?
  91. Clutch question need help right quick
  92. SoundPerformance Quick Spool Valve???
  93. exedy torque settings
  94. swap to non-acd transfer case ?
  95. question on oil filter
  96. Analyze these pistons!
  97. Aftermarket cast manifold for stock turbo?
  98. Knocking - Pre Ignition issue
  99. Max Output on Stock Rods and Pistons
  100. Knock?
  101. New Alternator
  102. FIC Bluemax fuel injector?
  103. pleeez bare with me here...
  104. Compression test cold and warm egine: differences
  105. boost
  106. need help.... :(
  107. acd t/c to non acd t/c swap
  108. Is it normal or should I worry?
  109. Anybody currently runing the GREDDY t67 25g kit???
  110. Need Help locating where the 2 thrust bearings go.
  111. Broken!!! I think
  112. Injen bov popping out Fixed Finally!!!!!
  113. starter rebuild kit
  114. Fuel pump voltage
  115. Spec super twin
  116. Car will not idle/stay running
  117. White smoke only on start up?
  118. My evo 9 keeps juking from second to fifth? any suggestions on what to do?
  119. anyone bought turbos from nolimtmotors??
  120. Different Types of Manifolds
  121. Flapping sound
  122. boost gauge problems?
  123. *Question on how to preserve stock clutch*
  124. ETS Intercooler question
  125. newbie injector install question (pic included)
  126. car wont start
  127. Evo won't idle. Any suggestions?
  128. Kelford 272 on stock springs/retainers.
  129. tial bov on evos
  130. do you think there is a chance?
  131. Need timing belt tensioner tool, IL
  132. machine shop around rockford Il
  133. BF 272s
  134. turbos
  135. Axles level 2 and level 5 from DSS
  136. Godspeed intercooler?
  137. Evo Idles down and dies>Need advice
  138. problem holding boost
  139. Gauging Interest: Evo VIII / IX Turbo Kit Around $1900
  140. Cam Gear recommendations
  141. Help!!! Coolant running low after motor build
  142. Clutch, Tranny issues mayb???
  143. Throttle Body Coolant By-Pass???
  144. Slave cylinder not bleeding
  145. Supertech or Cosworth?
  146. Just replaced my clutch!
  147. fuel pressure regulator question
  148. OEM clutch questions?
  149. Stock BOV fluttering at low boost?
  150. Ned help asap, Banjo bolts from block to turbo
  151. Pulling the Engine
  152. car isnt starting just cranking helppppp
  153. Idle relearn procedure
  154. Walbro Filter
  155. custom couplings?
  156. Defi BF EGT Issue...
  157. 5th Gear questions???
  158. Precision 6262 on a BR Cast Exhaust Manifold???
  159. COMP 280 or HKS 264
  160. Smart Opinions Please
  161. Diff choice help!!!
  162. Puck clutch break in, the real answer?
  163. How can i reinforce My Gear Box ?
  164. P0234 Wastegate Malfuntion
  165. Tranny, motor everything
  166. evo 9 gsr twin clutch
  167. Fuel Cut Randomness (yes it is already disabled)
  168. Oil analysis HELP!
  169. NLTS mod not working after clutch adjustment?
  170. oil leak near intake manifold
  171. HELP! Car over boosting!
  172. At home engine build parts recomendations??
  173. Atmospheric BOV?
  174. Need help putting a brand name to flywheel.
  175. Should I change oil or wait a week?
  176. Are these stock VIII injectors?
  177. oil temp gauge went crazy
  178. oil cooler cleaning?
  179. Clunking noise help!!!
  180. ACT MB7-HDG6 (6 puck) questions pics inside
  181. 1200cc and one walboro on E75 and FP Red?
  182. Which cams for gt3037s
  183. impact fuel cut-off switch?
  184. impact fuel cut-off switch?
  185. fp red or fp green better for this setup?
  186. Oil cooler kit choices?
  187. Need some opinions on this clutch!!
  188. Wastgate Question
  189. Replacing nuts & bolts in the Engine Bay
  190. turbo/mani. and turbo/02 bolt sizes
  191. signs of bad fuel pump?
  192. Timing Belt noise
  193. What Mods You Need For A Red On A 8
  194. Warmup Time
  195. Upgrade Path\Mod List for an FP Red on 93 Pump Gas and Meth Injection
  196. anyone running fpred with stock cams?
  197. PCV Valve?
  198. Oil Stick pulls out
  199. are these blocks the same??
  200. where can i get a evo 9 j-pipe???
  201. Oil pan heater?
  202. stock evo boost and fuel cut?
  203. Backpressure on high boost
  204. how do u drive after a tranny rebuild?
  205. Precision 3582 RLPS w/ mitsu housing
  206. Manley Turbo Tuff's vs. Crower's
  207. fuel cut? misfiring?
  208. HTA37r vs PTE 72MM
  209. how much is to much shaft play
  210. 2.0 Build?
  211. HTA 35R not enough?
  212. Transfer Case housing material?
  213. Quieting my AMS exhaust
  214. Towing an Evo8 do' and dont's
  215. clutch question
  216. What AMP fuse for inline fuse of trunk mounted battery?
  217. HP estimate and What will stock 9 Block hold safely
  218. evo 8 t-case in evo 9 GSR?
  219. Engine Ticking
  220. Dumb question about front frame/radiator support.
  221. Test drove a 04 EVO today and notice the tranny kicking the gear into neutral.
  222. Double Muffler, or HFC, Which is smartest for CA?
  223. GT3037S HTA, Is it possible?
  224. Weird Clutch Problem???
  225. any big HP evo Ix's using HKS M series m40il heat range 8 plugs?
  226. 02 housing help!!!
  227. Aftermarket throttle body with IAC?
  228. **Buschur Racing Short Shifter**
  229. Which Head Gasket should I get? Cosworth for the 9 or 8
  230. Clutch problems still.... =[.. please help
  231. Any experiance with this clutch? ACT 6 puck?
  232. Car help!
  233. best ground in trunk.. help
  234. Clutch Replacement!
  235. shifter cables
  236. rebuilding evo9
  237. Whine and grind
  238. HELP PLZZ!!! evo in need of help
  239. Bad Bish (II) on the Cover of Japanese Bonzai Magazine !
  240. Finished my IX install
  241. evo9 turbo on evo8
  242. how many variations of gt35 are there?
  243. Best Wideband....?
  244. Identify my Evo IX's exhaust
  245. how much boost can it handle
  246. Divided Downpipe (O2 Housing) Gasket
  247. Timing belt tensioner pulley bad?
  248. info changin my clutch and what tools are need
  249. Question about Exedy Triple disk.
  250. GT35r, 19-22psi, 340whp - Breakup, AEM EMS - Looking for ideas?
