PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. ayc pump failure
  2. Suggested maintenance for DD a built engine
  3. Suggested maintenace for DD a built engine
  4. Long rod or stroker?
  5. my car idles need help
  6. ISO Evo 9 2.0 Long Rod built short block
  7. Camshaft damage.
  8. Evo 9 MR 6 speed tranny
  9. Engine rebuild now a noise
  10. Evo 6 Engine Idle Problem When Cold
  11. Wrong IACV?
  12. Intake and exhaust cam position sensor the same part?
  13. Need Help! Noise after new oil pump
  14. Fuel Pump not getting Power after installation of several new parts
  15. Rebuild tranny
  16. Need advices on modifications on my 100% evo 9
  17. Evo 8 5 speed selector fork or shift linkage?
  18. Valves!
  19. evo 9 acd transfer case bleeding question
  20. Interchange for evo 8 block?
  21. Tial mvs install
  22. Interesting Fuel Issue. AFR's Lean out in two conditions. PLEASE HELP!?
  23. Keep popping out freeze plugs
  24. Evo 5 in evo 8
  25. evo 8 bucks/lurches under load, new plugs didn't solve the problem
  26. Huge gear teeth found in trans fluid --pic-- HELP!
  27. What do I do NEXT?
  28. DYNO TIME! Anything Else I need to do??
  29. Easiest trans to shift at high rpms
  30. Evo is dead after an backfire
  31. Crank help...
  32. evo fan controller compatibility
  33. BS Belt wiped out my Timing...
  34. G4JS Cylinder Head on 4G63/64 Block
  35. 2.3 clearances
  36. OFH, oil cooler, and turbo oil capacity?
  37. Sometimes hard to get out of Reverse
  38. Custom catch can build and install
  39. Carbonetic Tripple disk questions
  40. 6speed transmission mount replacement
  41. Turbo mod help
  42. Manely 100mm Forged crank
  43. Pull motor without head
  44. OEM Quick Connection Connector Question
  45. 6 speed trans PA NJ NYC
  46. Rich tip in causing stall
  47. EVO 8 Cranks, but does not start.
  48. Mishimimoto Radiator with OEM Fan
  49. connecting rod weight diffrence.
  50. Hard to get into gear when cold... how to fix it?
  51. Difference between 03-04 & 05-06 Nisei Upper IC pipes
  52. Twin plate clutch issue
  53. Help ideling problem
  54. Wtb fp red/ turbo
  55. Evo 8 with 9 Engine
  56. QM 8 Leg - inconstant engagement issues
  57. Fuel rail with port for fuel press gauge
  58. Difference between Exedy Stage 1 clutches (UFC, HD, PSI kit)
  59. Oil Pump Cover
  60. I'm not liking the FP silicone intake
  61. Evo8 ( weird probelm) hlep ...
  62. Skunk2 manifold Evo 9
  63. EVO 8 ACD options, thinking outside the box.
  64. Car jerks when letting off the gas
  65. Gains / difference of T4 twin scroll & v-band
  66. Best gearing for big turbo???
  67. Need advice on o2 dump leak. Bad flapper?
  68. Evo 6 and Evo 8 transmission compatibility?
  69. Quarter Master 8 leg race clutch hydraluic release bearing
  70. Vacuum pipe off
  71. 2.4L upgrade 4g63
  72. Has anyone tuned a CP9A AYC ECU?
  73. TME turbo?
  74. Pump Gas Build Q's & Experience Q's
  75. Rear diff whine ( after chaning Rear Bushings)
  76. ec5w legnum vs evo vs cm5a tranfer case
  77. Gasket Set
  78. Evo 4 and Evo 8 clutch compatibility?
  79. Injector Wiring Question
  80. Idle issue
  81. Intercooler Depth
  82. Clutch adjustment issue
  83. EVO IX MR not getting boost solenoid signal
  84. Anyone has a Sheepey FF kit installed? Need help
  85. Atp Gtx3576r on 93 pump results
  86. Sensor Question
  87. Self-Built oil pan
  88. evo 9 turbo shaft play up and down
  89. positive terminal wires
  90. ACD Question
  91. Best Tial 50mm BOV Spring with S2 cams
  92. FP Green BB or Blouch Dominator 2.0xt (JB)
  93. any info on Blouch 2.0 XTR
  94. will oil catch can make my engine breath better ?
  95. Need help on what recirculating BOV I should use
  96. Evo 8 gsc s2 cams
  97. Which plugs for E9 with COP kit?
  98. increasing fuel pressure (fpr) ??
  99. thrust washer question
  100. Oil in cam angle sensor housing normal?
  101. loss of power at boost
  102. Front diff differances - Wavetrac and Quaife
  103. Evo 8 will go into gear and not move.
  104. Turbo upgrade for evo 9
  105. Where should i get my Intake Manifold & TB ported?
  106. non acd t case with ayc diff??
  107. AFR's Rich under boost and Lean at idle
  108. 6500rpm shifting problem (no lock)
  109. Need help trouble shooting!
  110. Clutch suggestions/slipping clutch
  111. Transmission noise from drivers side
  112. JDM Evo 4 power steering pump rebuild
  113. rear passenger side Axle
  114. Engine bogs down at times?
  115. Seat pressure is 90lbs at _.___" for Kelford KVS63-BK springs?
  116. Need help!! Cam install problem
  117. Whalen Speed Engine Packages-Anyone?
  118. Randomly hard to start
  119. Acceptable method for checking installed spring height?
  120. Evo8 - Jun272 Cams
  121. Oil leak from front case
  122. Plastic injector tips??
  123. Competition Clutch Review
  124. Cam Journal Info ??
  125. Built Motor missfire\stutter problems
  126. Oem engine break in
  127. Making an FP Green turbo CA legal.
  128. manley I beam rod bolt specs needed!
  129. Getting Trans off of Engine
  130. Weird clearance problem.
  131. Please help - intermittent power loss when warmed up
  132. Help with powersteering
  133. Need desperate help!! Lol
  134. FP54 Green Turbo Fueling Needs
  135. Evo7 Piston Ring Question
  136. Lean at 4000RPM and Engine Dies
  137. 2.1 destroker feedback
  138. JDM evo VII idle issue resolved
  139. Holes on driver side of cylinder head - what size thread and pitch?
  140. Throttle body adapter plate
  141. Acd issues...any help is appreciated
  142. Manifold ets t4 twin scroll EFR 9180
  143. Idler pulley bolt. Where does it go?
  144. oem bearing thickness
  145. Front case/ Blance shaft
  146. 2.2L Stroker : Camshaft to revving 9000RPM
  147. Pipe with hole in it
  148. Different size fuel pumps on double pumper 255 and 450
  149. diy cop parts help
  150. double pumper fuel line routing??
  151. ACD lights on after installing....
  152. Rear wheels only turning when car off ground?
  153. Clutch issue
  154. How to Calculate Compressor Mass flow and PR
  155. New help. Broken ring lands...need shop advice
  156. oil in cyl 3???
  157. transmision evo 6 wanted
  158. A/C Compressor replacement
  159. Possible to install exhaust housing without pin lined up ix oem turbo
  160. Catalytic converter O2 sensor connector location?
  161. oil leak! underside of alternator and below
  162. Driving to tuner w/ out tune. FP Red....
  163. Soon to be build components. Feedback??
  164. o2 sensor wiring
  165. Airtrek turbo specs
  166. Would you use this crank?
  167. stock evo 8 turbo cold side leak
  168. 2.3 Stroker rebuild No Start!
  169. To do a VTA catch can or a sealed one on a 800+whp Evo?
  170. Oil Pressure at idle
  171. Turbo Upgrade
  172. Short block build
  173. Blue puff of smoke when revved at idle
  174. Clevite main bearings
  175. Weird howling, I think my turbo is toast
  176. Idle air control valve broken? *vid inside*
  177. Idle issues....
  178. Rear motor mount trans bracket bolt
  179. Weird clutch issuse
  180. Hissing noise with erratic idle
  181. AIR FUEL RATIOS and other questions
  182. Exedy Twin HD Engagement, Plates
  183. Oil Pressure risen over time?
  184. question about the competition clutch ??
  185. How do I identify my turbo
  186. Best Turbo for High RPM Setup?
  187. STM Sealed Catch Can
  188. anyone need a ported intake manifold
  189. Mitsubishi diaqueen Manual tranny fluid
  190. ACD pump pricing
  191. Bang sound
  192. blown head gasket??
  193. Car won't start, whining noise?
  194. 2016 best turbo for 900hp
  195. Hey everyone =-) Drivetrian question
  196. Small whinning noise.
  197. Front o2 code comes back on after new o2 instal. Need help.
  198. Spark Tech Ignition -Basic CDI Install?
  199. Boost leak test, air is comming out of the exhaust
  200. Never fails
  201. Another Identifying Cam Thread
  202. evo IV big misfire and sputtle.
  203. Which turbo will win on the street..fp red or gt35
  204. New to pte turbo
  205. Driving without ACD Pump installed for a few days
  206. 2.4 rpm question
  207. Stock engine overboosting
  208. wastegate springs!
  209. Radiator Question
  210. catch can. best setup
  211. Anyone w/ experience w/ stock downpipe cutout
  212. HKS TYPE R Which UICP?
  213. Erratic RPM problem,need help! with video!
  214. Evo ix running lean
  215. NEW EFR FF Turbo Kits
  216. NEED HELP!! boost issues and more
  217. Boost leak test
  218. Clutch Engagement
  219. boost leak test question
  220. Need a Head for 2005 Evo 8
  221. De-Pinning Evo Connectors
  222. Need help please my evo 8
  223. anyone tried out the 4.31 FD from Mfactory?
  224. Evo 9 not boosting
  225. fp turbo waittime
  226. best evo 8 head components out there?!
  227. Coolant Leak from Water pump Weep Hole Under Boost
  228. 2.3L built by tscomptuned
  229. Stock Evo With Atmospheric BOV
  230. Garrett GTW Series vs PTE Turbos
  231. Peakboost back in business?
  232. saw these tommi mak intercoolers on ebay
  233. Driveshaft carrier stud snapped and don't know how to fix it?
  234. Throttle feeling sticky on startup
  235. Oil on top on intake manifold from Valve cover?
  236. Atp GTX3576R bost creep?
  237. Need Non ACD transfer case please
  238. Afr's are funny
  239. What spark plugs to get for stock evo
  240. Rod bearing question. Using half/half bearings.
  241. anybidy has a evo 9 5 speed box for sale
  242. Anyone using the TRE 5 speed transmission adapter plate
  243. Turbo water line leaks
  244. HTA3586 vs Gen2 6266
  245. Cracked Valve Cover
  246. 3in test pipe
  247. Starts, idles for 2 seconds and dies
  248. evo 8 not moving after clutch installed
  249. transmission gearing
  250. Buschur SD vs N1 vs Tomei
