PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 [227] 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. HELP! Where to check ignition timing?
  2. Need Help! Question about HKS BOV
  3. AEM Announces Release of Redesigned Tru-Time Adjustable Cam Gears!
  4. Bigger injectors... needed?
  5. 264/272 vs. 272/272
  6. what should i do
  7. 5th gear grinding, or tranny problems?
  8. Installing SAFC - little confused...
  9. Got Headstuds?
  10. Those with HKS Exhaust, please read
  11. AFR Questions?????
  12. Unorthodox Intercooler Piping
  13. Diagnostic tools
  14. did somebody use apexi blow off valve
  15. K&N drop in installed
  16. Here are some AMS turbo kit pics...
  17. Do I need a Clutch??
  18. Radiator, how do you know yours is messed up??
  19. Injen technology EVO 8 performance parts
  20. Fuel Pump : 500 HP?
  21. UTEC experiences?
  22. What is the best high flow cat?
  23. Need help gettin a T-case
  24. ATS 3 plate install problems
  25. P0121: CEL Code :(
  26. EVO Air Intake
  27. Having some downpipe rattle
  28. bleed vs. spring and ball type mbc
  29. Greddy. Denzo 660 injecotrs not fetting
  30. What is the use of a high flow cat?
  31. Sparks plug change?
  32. Engine/turbo spikes?
  33. Driveshaft probs? any?
  34. Need advise, my radiator is leaking!
  35. Weird sounds after installing clutch?
  36. Need help with boost please....
  37. Intercooler and Clutch Pics !56K DEATH!
  38. What gauge is next most important???
  39. aeromotive fpr q & a
  40. did i get the right arp head studs?
  41. Bushing Question
  42. ball bearing turbo oil fittings
  43. What Oil Do You Use?
  44. NOT HAPPY 5th Gear!!!!
  45. Evo8 Fuel Filter location?
  46. fuel pressure regulator...where to find one ?
  47. Very Very Specific Fuel Question!!!!!!!!!!!!!!!
  48. Reading knock
  49. broken compressor wheel blades
  50. Cam Gear timing
  51. Well, my oil consumption has seemed to stablize...
  52. Installed Helix Oil Catch Can
  53. Something in fuel tank
  54. what difference would it make if i launch.....
  55. Question About Walbro 255
  56. info with cams
  57. My Upgrade plan, $1,500 to work with.
  58. HKS EVC V question
  59. Tach or shift light install issues / Help
  60. Gears get stuck when race shifting? PLZ HELP!
  61. factory boost control
  62. evo won't stay started, until warmed
  63. clutch weight vs. turbo lag
  64. Just ordered the Megan Racing DP
  65. boost question
  66. Length on JDM vs. USDM exhaust?
  67. Do I need a fuel pump if................................................ .............
  68. 1-2 missing gears
  69. Best Mod I Have Bought Yet
  70. RRE No Name Clutch "First Impressions"
  71. Wrecked my EVO...help!
  72. Transfer case removal??
  73. need help!!
  74. manufactured date vs. car problems
  75. ATP - Anti-Stalling BOV
  76. Where to go from here
  77. Cant find clutch replacement disks
  78. Anyone with Second OEM clutch going bad?
  79. HELP!! My EVO wont start!
  80. Apexi Power Intake filter kit, any dyno tests??
  81. Broken Stock Clutch (5100 miles)
  82. Apexi Alum Box...?
  83. Greddy type S and Air conditioning = funky idle
  84. New o2 housing, warthy upgrade?
  85. I need help...car died
  86. Will EVO turbo bolt to 99 Eclipse?
  87. Centerforce Clutch (Vendors check this)
  88. metal in oil?
  89. loud drivetrain whine
  90. Buschur Air Filter Install Question
  91. code read help
  92. Just got Espelir exhaust, NOT HAPPY!!
  93. I need help with greddy b-spec 2
  94. Cats with 3" in's AND out's...
  95. Can't diagnose this boost leak!
  96. Forge Atmospheric BOV
  97. RS lsd
  98. A disected view of a Greddy Type-S BOV
  99. What boost controller...?? Rock steady boost, no exaggerating.
  100. Better tuner - WORKS or Vishnu?
  101. What will it put down?
  102. Injectors
  103. Does your Walbro 255 fuel pump sound like THIS???
  104. Clutch pedal question...
  105. Clunking noise-gear shift
  106. Stupid ? about boost.
  107. Looking for some advice
  108. Got my car dyno'ed and tuned today (91 octane )
  109. Retrofitting RS Front LSD into 03 EVO VIII?
  110. Gt35r Dyno Slips
  111. Help me diagnose a starting problem
  112. Hot Day = No A/c!!!
  113. EVO has dificulty shifting
  114. For those of you who have removed the airbox cover, what keeps air filter in?
  115. changing oil??
  116. I believe my clutch is dead lol.......
  117. Ok boys and girls, who knows where I can find a short or long block?
  118. Evo and 60 Trim?
  119. i have read every post on turbo kits and cant make up my mind...
  120. lots of lag
  121. hks suction pipe with stock air box
  122. Rod Bolts installation?
  123. Do you guys recommend anti-seize on the spark plug threads?
  124. Bov to MBC setting ????
  125. EVO VIII vs SL600
  126. Fuel pump for 500 hp+
  127. Need complete cylinder head, where to get it?
  128. Bigger intercooler piping = better?
  129. Building a intake heat shiald?
  130. K&N "Drop-in" not a drop-in?
  131. Titanium Turbo found on ebay
  132. Boost gauge problem
  133. service engine soon??!!
  134. Quick question
  135. EXEDY Twin disc
  136. Hayward and Scott pics
  137. Melting rear bumpers with exhaust?
  138. Where to order Transfer Case ?
  139. Best EMS?
  140. Tomei Cam options
  141. overfilled my oil! What to do??
  142. Is it really that ridiculous for us to change our clutch?
  143. Greddy Titanium Catback
  144. Greddy Ti - Review
  145. Throttle Body Whistle..
  146. Engine Tick??
  147. INVECS II Automatic transmission problem.. is this recall related?
  148. Best Titanium Exhaust????
  149. decisions decisions
  150. BOV recirc question (need experienced people)
  151. new clutch whining noise?
  152. what accessories are worth getting...
  153. My turbo is dying.......
  154. Whats better for gauges? Mech or Elec
  155. My full report on HKS SSQV
  156. Intercooler piping pictures
  157. injector and pump- somewhat of a problem
  158. Experts Help Please
  159. Turbo Timers???
  160. Help, I need a manifold t3/t4
  161. What intake is this???
  162. 600whp EVO8!!!
  163. Gains with DP on stock exhaust??
  164. Quick Q. Apex or HKS TT?
  165. Quick question concerning exhaust
  166. greddy ti cat-back
  167. Clutch problem i believe
  168. question bout exhausts...
  169. incomplete water injection install
  170. Alcohol Injection
  171. What parts should I get for my car for reliability purposes?
  172. Still stalling!
  173. Ball bearing conversion for stock turbo?
  174. Oil Change
  175. 2003/2004 Clutch and Turbo Reliability
  176. Any reason the flywheel cannot be turned?
  177. optimal shift point
  178. Just installed a Megan Racing DP on my EVO...
  179. Blow Off Valve
  180. Fully Blueprinted Upgraded Fuel Injectors?
  181. Broken synchro fixed under warranty
  182. Boost gauge is not reading right
  183. Denso IW24 vs NGK BPR8ES
  184. front end clunk
  185. EGT Gauge with an Alarm??
  186. RNR GT35R turbo kit Installed!!!
  187. Where to mount TXS Dual MBC??
  188. look for a evo 8 motor
  189. First hot day - Walbro pump whine
  190. Turbo Xs Questions..
  191. New Clutch installed .. Now car whines . Normal ?
  192. Aftermarket tubo guys, what are you running?
  193. Ralliart ECU Expert
  194. Humming at 3100-3400 rpm
  195. spark plugs
  196. Extend TT harness?
  197. Witched Redline MT90 to Factory Tyranny oil 75w85 (Diamond Star)
  198. Is an intercooler upgrade worth it?
  199. Compressor map for GT3071R and GT3040
  200. Aftermarket Wastegate
  201. Buschur stage 4 pump gas settings?
  202. Ultimate-Racing's 3" Hi-Flow Cat & CEL?
  203. Just Installed DC Turboback
  204. Anyone Have Hks Cam Gears In Stock
  205. Wanted Ralliart ECU
  206. losing boost at redline...why?
  207. 75 mm Cat Delete pipe
  208. transfer case
  209. What is the potential of the EVO stock turbo?
  210. Removed HKS EVC = Not boosting past 10.5psi
  211. How many break in miles do you need to do with a new clutch?
  212. Buschurracing AXLE BACK EXHAUST
  213. Improving the camshaft cap retaining system
  214. Will I need a new manifold????
  215. Cast iron exhaust manifold
  216. Hks 272 Questions...
  217. injector wiring
  218. Is it too much boost
  219. Clutch Problem? File a COMPLAINT
  220. HKS Carbon Ti Exhaust is Installed !!!!
  221. Clutch master stage 1 kit: Good or bad?
  222. oil dipstick removal
  223. ACD in us evo 8?
  224. Can I tow a small trailer w/ my EVO?
  225. Weird noise
  226. overboosting: manual boost controller...need help
  227. WTF sub 13 sec passes?
  228. BOV leak after AEM SRI install?
  229. temp rise under boost?
  230. No crush washer on drain plug?
  231. Need help ?? FMIC is this right
  232. Manual boot controller help
  233. Stuck Installing Cam Gears
  234. Nitrous kit gets revamped...awesome custom work
  235. How much would you pay
  236. New Evo Fabricator/Tuner- WOTM
  237. The Turbokit is out and it's sick
  238. Does your engine Pulsate in the morn?
  239. Induction pipe for stock airbox
  240. BOV conclusion
  241. Intake
  242. Transfer O/H Kit
  243. EVO 8 MAS wiring
  244. To wrap or not to wrap tha tis the question!
  245. Not too happy, help me!
  246. Downpipe rattling. Please help!
  247. Road///Race Greddy Type-S BOV?
  248. injector install???
  249. Got my evo dynoed today on mustang dyno, check out my #'s, what do you think ??
  250. 615 Bhp ?= 501.5 Awhp
