- when should i get the 1st oil change?
- idle question
- Best Gauges?
- Evo 8 H+R Springs
- Evo 8 Turbo back + Check engine light quest.
- cam specs for lancer evo
- Lancer EVO 8 turbo timer
- Transmission failiure
- I need some help locating ....
- curb weight vs gross weight
- new EVO TO MUCH OIL ADDED
- IC spray not working???
- EVC V boost controller - problems with boost spike ??
- Another Dyno Result from Project Vivid EVO
- Stock Fuel Pump
- Buschur Racing 20G Turbo vs. Hahn Racecraft Super 20G turbo...the better one?
- 20G Turbo upgrade on Evo 8 possible now?
- S-AFC on EVO 8
- EVO 4G63 vs DSM 4G63?
- Monster Sport CF Intake Box???
- Anyone Fix the GloveBox Rattle?
- Get a good vibration resistant battery!
- Tranny noise
- Boost Pressure on Stock Turbo...
- Adding ACD?!?
- Differential Adjustement & Settings
- Engine & Tranny Limits
- Turbo timer
- need help evo 8 motor swap into 2g eclipse
- what grade mobil 1?
- Mitsubishi Mivec Motors
- idle problem
- ECU pinout for EVO2 JAPAN
- AMS Prototype exhaust done
- intake setup
- Difference on exhaust system
- Test pipes...?
- Immobilizer and the Ralliart ecu
- EVO understeer
- US EVO performance
- Heat wrap
- Pruven performance Evo VIII dyno results
- twin-scroll turbo?
- Does the EVO RS have manual windows/locks?
- IAT MOD CHIP on EBAY
- JIC Exhaust Install - 13 Horsepower Gain
- Whos right or wrong? But where is Waldo!
- EVO mods
- Octane advantage questions
- 309whp & 12sec timeslips for $400
- Shop manual for Evo VIII
- Evo ECU pin map
- Factory Accessories
- Best Spark Plug for good price $$$
- Rmr Products
- Vivid Racing Dyno Results
- A few questions on the 8
- Looking for a CatBack System!!!
- Ecu upgrade??
- ATB vs Clutch diffs
- Anybody got a turbo timer yet on the eight?
- EVO VIII Dyno Results
- Rattles, Squeeks, and general NOISES??!
- Evo 8 octane ?
- ECU Neutral Signal??
- Worried about losing low-end torque
- Anyone know of tool sets for Mitsubishi (Evo specifically)
- Mines ECU redline set to 8500rpm ?
- Evo8 Forged internals?
- Quickie Oil change question.
- Would 2G eclipse oil filter work on USDM evo 8?
- HKS idle stabilizer
- Turbo Timer
- Con Rods
- turbo timer install on EVO VIII
- Turbo Timer - Good/Bad Idea??
- 19psi?!!
- Idle Problems
- Newbie question: EVO 7 & 8 parts compatibility
- Evo 7 Turbo
- Anybody have the compressor map or maximum cfm for evo 7 or 8 turbos?
- Tech Tidbits
- egt temperatures
- Evo VII ECU's
- Will EVO 7 Apexi exhaust fit EVO 8?
- Misfiring system?
- EVO8 Carbon Fiber Wing...
- WRX(STI) Vs Evo
- Performance vs. Rear Wing
- Twin Scroll Turbo performance?
- Break In Period question
- Exhaust
- EVO VII Intercooler
- AYC vs. PERFORMANCE DIFFERENCE?
- Engine immobilizer
- Transmission
- injector duty and % upgrade
- Evo III Wiring Diagrams
- Evo III - HKS Exhaust
- Speed Limiter
- Link ECU for EVO8
- Brake pads for the track?
- Best Boost Controller and Turbo Timer
- How do various types of diffs affect AWD performance..
- Current Engine Management
- G-Force Motorsports Spec ??
- Problems with the Crankwalk??
- Stability Controls on new Lancer??
- What would it take to get EVO 7 into mid~ high 11s ???
- Blowoff Valve
- Evo/Eclipse 4g63
- Amazing Evos on a Rolling road dyno
- advice on installing exhaust
- Carbon Fiber Wing
- Cost of replacing tires?
- Boost Levels
- Installing Momo Steering Wheel
- Help!!
- Rant
- Evo 5 Wastegate Tunning
- how "bullet proof" is the evo 5 speed?
- Intercooler Spray Switch
- Claudius-- Evo VI turbo
- evo 8 turbo upgrades
- Crankwalk ?
- Evo Engine Break In [Super Hyper Mega Merge]
- word to the wise about mitsu and recalls
- greddy profect e-01 & e-manage
- EVO VIII Dyno Result!
- Evo V with EVO VI engine?
- The TRUTH about aftermarket intakes!
- Evo VIII center differential
- My EVO 7 with Power FC and Exhaust...
- UK evo8 fq300
- Bar vs. PSI
- Question for Claudius
- evo 7 dyno chart
- us evo lights and bumper
- noob questions
- overboosting on Evo VII
- ACD vs. Cusco vs. DCCD
- Whats the new Evo 8's Compression Ratio?
- Turbo Timer
- solution for sti battle...FQ!
- Missing plumbing from U.S. EVO
- Will Previous Evo Parts fit the EVo 8??
- Weak Tranny?
- Transfer case on EVO 7
- Need help sourcing Fields ECU harnesses for Evo 1 through 6.
- Clutch Slipping after 2000 miles!
- fuel pressure?
- Evo MAS help.
- Replacement parts for the imported EVO's
- Upgrade Path for U.S. EVO
- evo1-3 mod ques
- My Evo 7 turbo model number
- Evo intake/battery/bay questions.
- Obviously we arent getting the AYC/ACD...
- diferrence between 4G63 in an Eclipse and EVO 1,2,3
- What injectors?
- Reliability
- Turbo overspin
- Differential question
- injector size info
- Urgent Advice Needed
- Torbo pressure
- Need info/dimensions on EVO IV & V Intercoolers
- How much $ to build a 10 sec Evo???
- Evo & Crankwalking?
- Evo 6 Service Manual for Rear Axle
- NOS Warning - Please read
- My antilag system
- Breaking in a Turbocharged engine
- anyone with US Mirage with EVO motor
- When to switch to fully synthetic
- Evo VII alarm help
- Balance Shafts
- Evo4 Wiring Diagram? Service Manual?
- 4G63... outdated and archaic?
- Cams
- Prices for 4G63T Lancer EVO Motors?
- What mods should i do first?
- performance of crushed evo trunk
- Hks Sqv
- Question about Evo hood vent
- Hitting the Rev Limitter? - Claude/Michaelk
- How much for the EVO 7 AYC?
- Trust-Power PRofec e-01 Multi display boost controller
- Z1Auto.com now has its Lancer Evo section online!
- galant vr4 project
- Evo FMIC questions...
- Break-in period
- Best time to mod.
- Need expert advice from current Evo owners!!
- what's the best way to go about making your own intake?
- Change my metal head gasket?
- Ayc / Acd.
- ecu pinout
- stereo question
- Need Help with Engine Swap
- Makeing da evo a 10 sec car?
- couple of dumb questions:
- Electronics?
- Stock Boost on an EVO VII?
- Hks Camp
- Lambda Probes on EVO VII
- Aftermarket oil pans
- To Claudius/Michaelk - Replacing Clutch in Evo VI
- What are the differences of the EVO III engine and the USDM 95+ engines?
- Dump Valves vs. BOV Valves
- Servicing
- Making An EVO Street Legal
- HID's or reg headlamps
- Td05hra-16g6-9.8t
- EVO 7 timing
- good muffler ideas?
- Twin Turbo on the Evo???
- To Claudius - Few Evo Tech Q's
- Evo 4 paint codes
- Wooo hooo. I got my Mines ECU (VX Rom)
- Does an Eclipse head bolt onto EvoIV+ motor?
- To Claudius - TME 17" Tyre Size
- 95 Gsr
- Stupid Question
- To Claudius - AYC Oil Change
- Evo 7 fuel pump?
- GSX and Evo 7
- HKS 272 deg. camshaft adjustments ...
- Blitz SBC/DC (merge)
- intake: why in the engine compartment???
- which Exaust?
- EVOIII 6 bolt or 7 bolt motor?
- First Lancer Evolution Recall
- ONline Manual for EVO IV
- Need some help with my Evo 6
- handbreak button
- Active drivetrain reliability
- Question about an Evo 6.5 I found
- EVO 6 wiring loom diagram
- EVO IV's AYC problem
- Thermostat question
- Best Motor Oil for EVOs
- Titanium exhaust system
- Adding AYC
- Modification City!!!
- Ralliart Sports ECU, or MINES ECU?
- Does drifting cause damage to the diffs in an evo?
- Torque Settings
- Help please
