- Is my turbo wearing wierd?
- Buschurracing's Upgraded 20g who wants it..
- APS BOV installation
- Turbo Questions
- Looking for the best universal muffler...
- Perrin BOV
- twin turbo evo?!?
- New Fluid For Clutch Install??
- ACD ATF leak
- help my compression is 130 i think its going to blow
- P0135 code?
- need help with mod questions
- clutch line restrictor removal help with sliping clutch?
- clean engine picture
- what size is the stock donwpipe?
- SES light
- For you ssautochrome peoples...
- Anyone in the US makes longer gear ratios for the GSR?
- My down pipe doesnt clear, do I have any options?
- Hks Gt 3040
- Oil leak....
- Crower Stg2 Street/strip Cams? Anyone got them?
- need help
- Need Help Asap!!!!!!!
- What do u guys think of the IKEYA sequential shifter?
- Which Test pipe?
- Can anyone do flashes on the Evo 7 ecu?
- HKS RS replacement filters?
- How much does the stock flywheel weigh?
- Br Deluxe Upper I/c Pipe Kit
- Intake before exhaust?
- Installed Dynomat,now car wont start
- Question about MR Transmission
- aftermarket turbo = less need for FMIC upgrade?
- Guages
- br500 and AEM EMS anyone?
- stock clutch, hp?
- A Differant Cam Question...
- uego gauge installed.
- The biggest waste of money?
- Closed loop, Open loop?
- transfer box
- TC\TC fluid question???
- Stock D/V (BOV) installed wrong???
- BR Throttle Body & Intake
- GReddy Type S BOV
- Any damage to stock valvetrain
- MR Down Pipe clearence.....
- Best Evo Power mod of 2005, from Buschur Racing
- Seriously how much power SHOULD this make
- cusco differential
- Helix tip to close in this pic?
- HKS SSQV Vented with HKS EIDS=???
- boost wont raise...?
- rvm i/c pipes. wont fit?
- Question: Is it ok to drive the car w/o the MBC hooked up?
- Holy Smokes!!!
- Any vendors that carry the GM 3 bar map sensor
- to those who have replaced a clutch....
- intake/bov ?
- Turbo spool at 1.3 then .5 and then .25
- Anatomy of a buildup: Mild to wild in 72 hours!
- 368whp pumpgas (stock turbo)
- Conversion to RWD...Possible??
- Will this (HF CAT) work?
- Need car electrical help
- Just got a dc sport exhaust
- Stock standard Rev limiter
- Transmission Oil
- Greddy type s blow off
- full t/b. exhaust
- Anybody using the "NO NAME" Clutch from RoadRaceEngineering?
- P0300 Code Poll
- Gutted Catalytic Converter
- what is a good AFR to aim for in the evo?
- Not starting a war im j/w
- HP Loss with HF Cat
- idle dip with safc and hks rs intake
- Thumbs Up To Fuzion ZRi Tires
- 2.5 vs 3 inch downpipe again?
- idle issues
- Help with Greddy Turbo Harness
- Installed cams 264/272
- is there a FMIC that comes with upper and lower piping?
- Too Engine Builder's
- Pictures of color wiring for ecu
- torco fuels??
- what do you guys do??
- Please Help Need Picture
- Helix dp 76 or 80mm?
- should I get a dp with flex?
- RC Engineering is the Deal
- Evo 8 Turbosmart Direct Replacement Bov
- Cone filter with Stock Air Scoop
- I need help w/ GReddy boost controller
- Walboro ONLY OPTION?
- Any bugs in the RS helical TC swap?
- Anybody with the Apex-I RX6 Turbo kit?
- How are the 05's and MRs clutches holding up?
- Opinions on performance mods
- Need a new axle back exhaust for my B&B catback
- How good is the stock intercooler?
- HKS cams and redline
- HelP!!! WhaT HapPeneD???
- Now how did that pop off???
- New HKS 280 duration camshafts for Evo8!!!
- What Mod. Should Be Next?
- How hard is it to install Transfer case??
- Just installed my MBC :)
- Which Intake Filter? Worth IT?
- Think I have a problem with the AWD
- BUSCHUR 3" SCCA CATBACK
- BG Syncro Shift question...
- which DP are you using with your Greddy Ti?
- VIII MR Grp N has dogbox
- intake Question
- Clutch install...
- RVM intercooler pipes and Hallman MBC installed
- what do you think about VSR exhaust
- Injen turbo-back installed...
- Vishnu Cam Gears, stock cams, what setting?
- Radiator Drain Plug
- Greddy PRofec B II Version 2 valve
- Internals
- HKS Kansai Service
- which turbo would buy?
- Can anyone identify this turbo?
- Profec B Spec I...balance???
- downpipe question
- how much hp per psi and stock boost quest
- watercooled hardpipes for those interested:
- HKS rs intake kit question
- Best 3 inch exhaust with little to no interior droning/resonance?
- IC pipe observation.. Catch can is pointless.
- **Flashing**
- my egt only reads 200 F?
- Looking for advise/Experience
- Ecutek
- HELP!! Just installed exhaust and having some problems
- What a good laugh!
- P0300 misfire and S-AFC
- APS Intercooler
- Hks Evc 5 Help
- Exhaust question
- ACD Fluid
- Ferrea Stainless Steel Valves on Lancershop.com
- Evo 7/8 HPI Turbo Outlet/O2 housing
- Second Gear lockout when cold
- Found a T-case for a great price!
- Cheapest Best Turboback
- i need help with Imfo. on Evo engiens
- any gains from downpipe & test pipe w/ stock catback?
- Anyone used one of these FMIC's?
- What size throttle body does TTrix use?
- Where can I get an LSD for the transfer case?
- Thermostat Install
- Have a few questions about Exedy twin disk
- Kartboy shifter and bushings installed
- Hollinger Dog Box: Any good?
- Dyno Run on 01-05-05 good average or bad...
- Cam install tomorrow/ have 1 question
- Upper IC piping keeps blowing off
- Pulley Belt Tensior (Help)
- Blitz FATT not working in auto mode
- Who would u recommend for Stage 5 headwork?
- Knife Edged Crankshafts
- turbo lag...
- Hallman pro with Tial ext. wastegate
- Turbo XS intake
- Upgraded exhausts and MAF readings
- Apexi SAFC II and HKS EIDS Question
- External dump tube for stock turbo?
- BIG leak after install of clutch
- How to make 260+ HP
- spark plugs
- so my EVO fixed it self.. weird
- will adding a DP make your car louder
- Alcohol/Water Injection on stock turbo....
- Helix TB questions
- Boost wouldnt go pass 11 psi after MBC installed
- I have access to a Dyno, but its 2wd, how is the conversion done?
- drag launch
- clutch and fly wheel
- Greddy Turbo timer, change face color
- Will cams void your warranty?
- Sun Hot Inazma Universal Hyper Voltage System?!!?
- TB exhaust and tuning
- Exedy Triple Carbon Installed
- Need help about Evo Engines
- Greddy Profec Type-S
- Installed Height on Valve springs???
- ??ATS clutch disk replacement??
- HElp Clutch install
- Stock turbo hp numbers
- how much hp increase from a
- Quest for Turbo knowlege
- 2k miles and transfer case breaks
- 1.3 boost on avcr ok?
- Sticky Throttle?
- Stock Boost taper 20-15psi..this ok?
- fuel pump problems
- Injen intake quick Q&A HELP!!
- Tuned for c16, but will c12 work.
- Pics of Coil per Plug Setup
- ACT install
- Was your clutch covered under warranty?
- Random Misfire Check Engine Light
- ONe Question about SAFC II
- Megan Racing DP on eBay (part II)
- got questions regarding SAFC
- Any Suggestions for a flywheel?
- 10 sec evo
- Comments on an APEXi GT-Spec exhaust system?
- Need Help on Intake Pipe
- Alcohol/Water injector
- who wants a real turbo upgrade...hehe ! I do I do!
- about evo engines
- EVO Set up Question
- Crower cams?
- A question for those of you with the deceleration noise
- BG Synchroshift is awesome
- Blitz SBC-DC set up instructions
- ECU + minimal tuning results *pics inside*
- 400 Horsepower on Stock Turbo.
- When do you need to upgrade the stock fuel and or FPR?
- Tial BOV
- Engine Management System; which one?
- Profec B spec II trouble
- Greddy turbos??
- Turbochargers.com EVO turbo upgrade
- Weird RPM problem in MR
- EVO VIII 5th gear swap
- Evo 8 oil question.
- ACT Installed and lovin it!!!
- Fine tuned my Dynoflash (AFR/HP results)
- Questions on Megan Racing Exhaust
- Installed my cams and head studs today...
- Evo in trouble
- Stock turbo inlet diameter?
- magnus intake OMG
- Tilton clutch
- Turbo XS catback exhaust?
- Greddy type S impressions
- Forge BOV review
- Motec M800 VS AEM Plug and Play
- Defi BF Boost Gauge Problem
- Espelir Downpipe install on 05' GSR. Impressions...
- Helix full exhaust problems
- Penzoil Synchromesh: Long term review
