PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 [149] 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. HKS Easy Writer = Awesome
  2. FQ-320 = MR + HKS Super DraggerII, HKS intercooler pipe kit, Change in wastegate
  3. Ported & Polished Head
  4. 6.5tme vs a stock 05 turbo
  5. mitsu is covering my 5th gear syncro /but clutch question
  6. So i took my car down to Extreme Turbo Systems
  7. how can I know if it is the clutch or the synchro?
  8. bushing kit
  9. Buschur Million Dollar Fuel System
  10. Best deal on built engine?
  11. Transfer Case (ring And Pinion)
  12. TURBO help 3040R VS GT35R Q's... I have search please read.
  13. cam install help
  14. 1/4 mile....fp green or 50trim
  15. How many thousandths?
  16. Measurements for Evo 9 turbo flange:
  17. car won't start
  18. Forced Performance intake arm
  19. Apexi Boost Controller Help
  20. 2 step ?
  21. WORKS Short Shifter, I love it!
  22. Carbing air suction kit
  23. Any Help would be appreciated
  24. which valves to get and cams
  25. What spark plugs should I run in a 2.3 Liter?
  26. a friend blew his engine what do you think of this....??
  27. Do not buy from "Late Apex"
  28. dont know which pistons to go with
  29. Rear end shot?? Help plz :confused:
  30. Clutch Help
  31. lancer evo 8 5 speed block/evo8 6 speed block
  32. My Broken Evo...
  33. mods without a tune???
  34. best way to hook up MBC
  35. Boost
  36. For those who want Evo 9 'TME' turbo
  37. what to lube BOV with?
  38. spark plug gapping
  39. which flywheel
  40. Engine blown !!!!
  41. What is the flow rate of an IX fuel pump
  42. Megan DP intall question.
  43. Is Mitsubishi selling me wrong Transmission Fluid?
  44. Ideal specs for radiator fan?
  45. Symptoms for Transmission Fluid Change?
  46. Location of Tranny Bolts??
  47. Southbend OFE Clutch Install Pics
  48. Why is my car boosting on my gt35r when I have my forge mbc to the lowest setting.
  49. RPMs rise when clutch pushed in?
  50. Boost controllers and a new one coming from BR
  51. Bonzai - Dyno Flash Evo WR vs. EVO Shootout !
  52. what can i expect?
  53. Forge Rs Dv Owners Help
  54. What oil is everyone using in their built motors???
  55. My FORGE MBC sucks!
  56. How long is the waiting list for the "Green" Turbos?
  57. timing belt slack
  58. rnr 50 trim?
  59. evo 9 cams
  60. ShortBlock evo3... Head evo 8?
  61. Oil Catch Can Fitting Size?
  62. Boost Creep Fix? Hitting 21psi on wastegate?
  63. How many times have you adjusted your Exedy twin?
  64. ACT clutch differences
  65. '03-04 Evo VIII: Factory front LSD the ticket in Auto-X?
  66. is a I/C sprayer wor it,
  67. Evo VII GT-A Help!
  68. AEM A/F Ratio Wideband
  69. Modification Sequence help = Benefit EVOM Members
  70. Jdm Mr Bov
  71. Upping Boost = Roaring Engine?
  72. Turbo Timer
  73. Please help.....
  74. The official hyundai 2.4L G4JS (4G64) thread
  75. tre or shep trans....
  76. can solid mounts cause false knock
  77. oil light blinking?
  78. Supercharged Evo anyone???
  79. AMS KIT vs BUSCHUR KIT
  80. NEW Product Release: AMS Drag Rear Differential Setup
  81. NEW Product Release: AMS Lightweight Front cross member
  82. NEW Product Release: AMS Brake master cylinder brace
  83. How to install ATP gt35r?
  84. How's this Dyno sheet look to you guys?
  85. backlash adjustment on Evo rear diff.
  86. Grass Fun
  87. tomei forged rods ???
  88. QTP electric cut out
  89. Best intake system for Road racing?
  90. Nisei LCp?
  91. question
  92. Port and polished exhaust manifold?
  93. Evo IX transfer case issues
  94. lifter tap and loss power!
  95. Problems with Exedy Twin HD
  96. has anyone ran testing on different exhaust
  97. Pump Gas record???
  98. Turbine stops to blow at 5-6K rpm
  99. Drop in IAT by disconnecting hot water feed to the throttle body?
  100. Perrin short shift drama's
  101. transfer case questions...
  102. clutch pedal squeak,ACT hd clutch,help
  103. Can a helical front diff from a acd transfer nox be fitted to a non acd transfer box.
  104. only boosting 10PSI ? ? stock solenoid??
  105. EGT fitting Brass ~1400F
  106. Fuel pump holding me back?
  107. Car just quit, please help
  108. Spark Plugs?
  109. clutch problems help!
  110. Forge mbc. Each click represent's how many psi?
  111. boost controller with stock everything?
  112. Tranny popping out of fifth gear (grumblerrrggg)
  113. bf cams
  114. What would you change your HKS 272's for?
  115. transfer case life expectancy?
  116. new gt35r setup with stock ecu
  117. Evo Intake-- whats Stealthy, but works
  118. Clutch suggestions
  119. Green related question.
  120. 50 trim Spark Plugs???
  121. Toga Oil Filter
  122. boost fluctuation question/help
  123. Help...gears locked out
  124. best turbo?
  125. Problems, 2003 Evo VIII recently purchased
  126. new IC set up and mani...new tune?
  127. Forge diverter valve flutter
  128. Need help with buschur exhaust!!!
  129. Temperture
  130. Helix Rods.. is anyone using them?
  131. Oil Light?
  132. Tranny Grind ?
  133. Texas Tunner?
  134. Boost Leak Test Question???
  135. Vendors - who has a black Forge UNOS in stock and can ship ASAP?
  136. Can someone help diagnose this oil leak (photos)
  137. ARC induction + Greddy UICP
  138. Question about Waste Gate?
  139. i need advice
  140. HKS R-Type FMIC
  141. fully built evo VIII mr questions
  142. To convert your car to run E85, you need to...what?
  143. What's involved with installing rod bolts?
  144. Buschur pure power package?
  145. How many teeth on 4.111 and 3.73 gears?
  146. Ams Vsr + Green + Dyno!
  147. APS 3.5 turbo back and other mods?
  148. Whats the best Crank Pulley Damper ?
  149. Solution to leaky OEM Throttle Body Seals running higher boost.
  150. adaptive ECU how true is it on a EVO IX
  151. 280's with 272's cams
  152. Quietest high-flowing turboback?
  153. I have a WORKS BOV and a Bailey Motorsports BOV. Which to keep???
  154. 1000cc injectors on stock ecu doable??
  155. GSC S2s or 272s with 4G64 Strocker
  156. Clutch Install Help Evo VIII
  157. Which intake has the most power gains?
  158. best way to pull the head
  159. Boost leak test with a external wastegate??
  160. [b]need Help With Boost Problem[/b]
  161. Best way to pull motor?
  162. cosworth exhaust cam to big???
  163. Help with Buschur intake pipe install
  164. Vibrating pedal
  165. where does this tube go?
  166. Transmission syncros for evo 7
  167. DC3 catch can installed... & a CEL???
  168. How to correct P0069
  169. Help with exedy part!!!
  170. Fitting a test pipe
  171. Evo 8 ACT Clutch Noise
  172. Is this how to connect Turbo/Wastegate/Boost Control Silenoid?
  173. Getting used engine HELP
  174. Pictures of my clutch install
  175. Evo9 ECU compatablity
  176. cam senser
  177. AEM and 2step soft cut/hard cut configuration...
  178. fpgreen video's?
  179. Tuning Question
  180. manifold change
  181. 05 t/c into an 03
  182. Evo 9 owners: Please post ur dyno sheets(preferably Mustang dyno) and list parts Plse
  183. 3" O2 housing w/ external dump?
  184. Downpipes that clear on IX?
  185. Thoughts on going straight methanol? Fuel requirements? Ignition?Engine build?
  186. Need Advice on Boost, Mods, !Power!
  187. stoker kit
  188. How to tell if you have cams?
  189. Exhaust Sounds
  190. MR diaqueen p/n??
  191. Car only boosts 1 bar, 4th+5th gear turbo doesnt spool til late.
  192. Someone please help. Boost problem. .
  193. Bango bolt
  194. Is that Fuel Cut off
  195. 2.4L build
  196. How to Open Hallman Boost Controller?
  197. What milage should i change Sparkplugs at?
  198. adding oil squiters with 2.4L swap
  199. Repercussions of big cams and stock IX turbo?
  200. AC issue.
  201. boost not changing please help
  202. anyone flow match their injectors?
  203. BR STage I IX pump gas - perfectly shaped dyno sheet
  204. Testing Effect of High Flow cat vs test pipe on Stage IV Evo IX
  205. acd transfer case in non-acd car
  206. bearings with 2.4L swap
  207. Re-circulate BOV with stock air box: quite
  208. driveshaft
  209. recommended clutch
  210. UICP that will work with AMS fmic
  211. porting an evo 8 cylinder head
  212. timing belt
  213. hard to start
  214. running a DP+cutout on a stock exhaust?
  215. EGR CEL code
  216. Is the evo 8 rear end limited slip
  217. Stage 2 Has Started!!!!!!
  218. dnp t-4 manifold installed
  219. Question about "pull" type clutches...
  220. Apexi power intake drop-in?
  221. Ring and Pinion from Shep Trans Available Soon!!
  222. How do I run a boost leak test?
  223. Stock UICP no go.
  224. AEM Tru Boost fixed
  225. AC question?
  226. Boost too low
  227. Exedy Twin
  228. Exedy Organic single plate clutch and flywheel
  229. Anybody know injector lag timing or dead timing of AMS 680cc injectors?
  230. 2.3L vs 2.0L
  231. Learning to Weld
  232. clutch install ?'s
  233. P0401 Code and it's not a hose that came off..
  234. wat plugs and radiator cap for EVo9
  235. Anybody have the ATP 35R Setup?
  236. Break in lube for cam install?
  237. bosch o2 sensor
  238. hesitation pop
  239. Anyone have pictures of ported exhaust manifold uncoated?
  240. Intake manifold question
  241. invidia vs helix
  242. 4" Exhaust!?
  243. What psi should the stock diverter valve hold?
  244. Full Race mani and Pruven Tune
  245. 2.3 l vs 2.0 l
  246. Evo IX thorwout bearing noise...normal?
  247. Just got in E98 Going to try it with my ETS T-4 67 Turbo
  248. loss power after cam install
  249. Hose too close to Turbo Manifold?
  250. Clutch Question
