- roller rockers from a 1g or 2g dsm on ix evo?
- Trans/Diff/Tcase fluid question
- Kit ACD pump and valves
- Buschur Racing 3" Catback Falling Apart
- Breaking up while cruising/running lean and shutting off?
- IX thermostat housing
- Stock frame ff and 3 port
- Evo 9 mivec plugs part number?
- Mpg on built motors
- Which Cams for 2.3l+ported head
- 5 Bolt Hub Swap?
- im ready to build my engine .. Opinions in which company to do it with or shop????
- STM re-wire kit now relay getting very hot, melting relay connector
- Car cranks but not starting.
- Who Sells R&R Rods besides english racing?
- 2.2 stroker
- Exhaust manifold gasket leak
- To use 4G64 OEM cran or not to???
- max power on stock engine
- How long do you let built motors warm up?
- evo 6 injectors to run
- 4g69 pricing??
- Whining During Accelerating
- HKS twin plate clutch rattle --Video--
- Mivec Feed Line Banjo Bolt Leak
- hks 7460 kai and idle issues
- clutch replacement
- Transmission/clutch issues
- How many miles on your built motor?
- Cam timing and valvetrain noise
- Evo 450hp
- Is this crank usable??
- Noise from head at 2k RPM, confused.
- I want that torque, 2.3 or 2.4LR, already have built 2.0
- Best short block under 4k
- Is this the ayc pump for my evo 9?
- Breaking in on a big turbo
- 416 walboro need new regulator?
- Should my wastegate actuator have a hole in it?
- Manual Transaxle Control Shaft pin
- 60K Service kit price
- Any evo 8 head out there
- Zero PSI
- Evo 8 Stalls Every Time Clutch Let Out
- Help!!!! Lots of white smoke at idle smell like oil burning ..
- sas ports in the manifold
- ACD problems, bad computer? bad guage?
- 02 Dump for stock turbo?
- Evo IX FP Green DBB, oil feed from head or O.F.H
- rods pistons combo 21mm fit evo
- why don't these injectors fit
- Pictures of Engine Block w/107k miles
- About running a 75w140 transmission weight
- Glitter in EVO9 oil - engine disassembled
- Loosening Turbo to Manifold bolts/nuts: how to fix?
- you're not above it. It can happen to you too!
- Evo 9. Cams
- Litespec Evo 9 Titanium exhaust broke! helpppp!!!
- Oil pressure strange issue
- Shifter movement in 1st and 2nd gear
- Banjo adopter and bolt size
- Evo 9 bov question Help!!
- Going ghetto Garrett - KAMAK
- Does any one have experience with the FP 71HTA CHRA upgrade?
- Unplugged Cam angle sensor and intake cam sensor and still runs
- Possible transfer case whine ? vid inside
- A/C related issues
- Both Markings on cam gears post to line up with Valve cover?
- Clutch Smell
- Holset powered EVO 4
- One flash of CEL, Tephra v7
- New engine vibration after service
- Possible oil leak?
- Car turned off while driving... Wont start now. What could it be?
- URGENT Boost leak?
- Best place to buy hardware to fabricate custom O2 dump?
- evo 4 and 8 engine mount differences
- Head and exhaust cam hurt, jumped timing, need input for cause
- new member with eclipse
- E85 oil discoloration
- is my clutch disc backwards?
- o2 housing bolt install? Pic included.
- Exhaust valve leak
- boost pills needed!
- New built motor low compression across the board
- cam gears and 272s
- Engine cutting out at higher rpm - bad camshaft position sensor?
- timing belt help needed asap
- Harsh Spark Blowout
- 10.5 Hotside crack, need opinions
- Evo 8 clutch issue
- Severe lack of power, running rich under boost
- Tial Q with Perrin intake?
- Will Code P0107 prevent the car from starting?
- Competition Clutch Triple Disc Clutch Kit
- Need opinions on Competition clutch 2600 - road racing use
- How do I remove this shaft?
- Engine Help!
- Battery voltage
- Need your help
- Headgasket help...
- Engine whine
- knocking
- Intercooler
- weird sound when braking only on Snow traction mode?
- down pipes and o2 housing
- how does this happen (Inside my rear diff)
- upgrading your double pumper
- EBay licp & 3" turbo back
- Competition Twin disc
- time for timing belt.
- broken spark plug tip why? scortched pistons too?
- Help: Sudden oil pressure loss, oil light on, crap idle
- eBay o2 housings: Once they crack weld or replace?
- evo 8 with COP misfiring in cyl 1-4
- Clutch installed, Can't get into 5th Gear
- Boost leak test question
- Brand new headgasket leaking?!?
- 2 pc Englewood aluminum CrMo driveshaft
- Idle surge/bounce
- Coolant system upgrades for a car ran hard
- Excess blow by even after catch can
- Who made this Manifold ?
- Evo IX OEM BOV
- Mobil1 Racing 4T 10W-40 4-Cycle Motorcycle Oil (1 Quart)
- My BOV!
- Bigger turbo, stock licp/IC..
- URGENT! Clutch kit selection
- Car does not want t log, reflash or read ECU!!!!!!!!!!!!!!!!!!
- 02 housing bolts and stud sizes?
- axle/driveshaft question
- Evo 4 Idle Issue, Misfire/Sputter, and Hesitation
- 3" or 3.5" DP for FP Black.
- clutch pedal pressure drops while driving
- help?
- Evo VII RS slight stalling problem and hot start issues
- car wont start..help!
- Evo V clutch swap concerns
- IACV issues - 2003 Evo
- boost issue?!?
- FP Green on stock internals?
- Best fitment downpipe for 2006 mr?
- Evo Radiator Leak
- Help! Question with sputtering/jerking Evo 9
- Need Some Advice
- AMS VSR and Upper Intercooler Pipe
- Evo ix OEM Turbo details
- Clutch Issue?
- 2.3l stroker reliability. How many miles on yours?
- evo 9 rear diff cover spider cracking
- Need advice on boost leak
- cams
- sparktech cop swap from 8 to 9
- Any 6 speed with 4.0 final drive real world users?
- Clutch is stuck! Need help!!!!
- Clutch torque!!!!!specs! Bolts are loose!!!!
- 2.4 LR Off the Shelf Pistons
- which exedy clutch is it ? *pics*
- Stock 4g64 block power
- US vs Italy: How can you guys achieve so big power figure?
- Evo Keeps breaking shafts
- FP Black wastegate actuator
- 6266 confusion
- God.......I hate mivec
- Trans/TC/Diff Fluid change- grind 4th
- Buschur Racing Pro Catch Can
- Crankwalk? or Bad IAC Stalling problem
- RS✩R Ran Up (The latest in Snake Oil technology?)
- Need a 4G64 head gasket that supports high HP
- FP Black with Injen intake
- Think machine shop messed up! NEED ADVICE!
- Turbo Feed line question Please help
- 3rd gear grind after clutch install
- FP BB Black, How long will it last?
- Any idea where I can buy 4g64 block, from a seller on this forum.
- E85 Time! Just some insight first
- Greddy LS Spec IC Kit Evo 8 - 9 differences
- Horrible rear diff whining
- Blow off valve leak with boost test?
- Noise coming from clutch video inside
- Engine bracket ? & Alternator question
- O2 dump install issues
- Evo 8 strange decel noise
- New Billet Turbo Pics For Your Enjoyment!
- Transmission shop in AUSTIN?
- Weird Misfire/Hunting Issue. Need Some Insight
- Stalling while driving
- 6Speed on evo ix mr failing
- Undertray for Evo 9 with AMS Oil Pan
- Cleaning out a Cusco catch can
- Evo ix idle bounce
- Comp Stage 3 Issues
- What to look for on spun rod bearing
- help identifying wg actuator brand?
- Evo 8 misfire under high load
- Exhaust
- Lancer Evo II project Philippines
- Best instant/spoolin Turbo?
- Problems shifting, any ideas?
- Is my TurboSmart actuator the problem?
- I give up, where's this bracket go?
- Evo 8 rear diff in Evo 4?
- new clutch
- What is the Best Radiator Fluid for my Full Blown Raditor?
- eBay exhaust question
- Output shaft help
- A little insight please.......
- Buschur 2.3L short block problem
- intake BOV issue with fluttering
- does the compressor cover survive a thrust fail?
- Non-ACD Diff Casing
- Evo 7 GTA Tranny Cooler
- Exedy Twin HD question #2
- Want to get close to 400hp out of my evo 8...!!
- Break up on wot
- dedicated turbo lubricating
- Oil leak...boost
- tcase breather
- Turbo.
- which clutch and flywheel should i get that can handle 300+ whps?
- barb fitting for fuelab fpr
- Looking for a Oil Cooler
- Evo running rich help!
- Budget Turbo Build
- EVO 8 help needed
- ssqv D version
- Serious lag issues and wont spool past 23 psi.....20G 68mm
- Replacing valve seals on car - Easy!
- Removing Driver's Front Axle
- oil decisions
- Transmission noise questions
- Eagle crank or oem crank
- Help car doing fuel cut on boost even at 1 psi .. I camt get into boost
- Walbro 450 double pumper?
- Can a new exedy twin rebuild disk cause slipping during break in process?
- Evo ix no fuel pressure? Running lean?
- Beaten to Death: Piston/Rod Combo
- Getting cam sensor and crank sensor code car runs and drives but shuts off some times
- Anyone know what kind of rod this is
- Clutch failure
- Block question.
- need evo 9 engine cover to buy
- Evo 9 dying in 5th after WOT pull
- egbp sensor
- What hp/tq limit do I have with OEM Head bolt
- P0340 code..no camshaft signal!
- Need opinions on turbo swap
- evo 9 build question !!
- Best evo 9 setup want 400whp
- Magnus intake/throttle body gasket
