PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. New Evo, whts wrong with this clutch???
  2. odd hesitation under any load
  3. Fresh Valve Job not sealing?
  4. Pressure in rear diff Evo 8 help
  5. Diamond race cars billet steering rack
  6. need reviews on Manley SLW Crankshaft
  7. EVO IX- engine runs a bit rough
  8. Looking for diffs upgrade
  9. Radiator Solutions? Car goes above half way in city driving situations?
  10. Anyone running a performance Intake Cam Gear?
  11. Gcg turbo
  12. Steering column issue
  13. Leaking tranny fluid?
  14. HELP PLEASE - I broke something :(
  15. FIC 1120 question
  16. Engine carnage pics.
  17. Manely I beam TT rod side clearence
  18. crank pulley? its need to be changed?
  19. FP vband o2 housing fitment
  20. Burning clutch smell and oil leak
  21. Synapse still the best for driveability?
  22. Precision turbo clocking
  23. Question on ets Air filter kit
  24. To all synapse diverter valve owners. I need your help!
  25. Ayc pump for Evo 7 GT-A
  26. Reliability of a Evo 8/9 at 900whp?
  27. Yellow Jacket or OEM
  28. After marker cam bolts / built motor?
  29. Dial bore gauge?
  30. LICP: ETS vs. MAPerformance
  31. Weird noise around 2500rpm
  32. Evo 8 Diverter Valves and Blow Off Valves
  33. Potential OEM manifold and turbo blanket
  34. Is it possible to repair quaife lsd?
  35. Drop in outside temperature, transmission now feels a lot worse... Really?
  36. oil squirters
  37. 450 lph on stock lines
  38. Lean spots and 3k stumble
  39. Car sounds horrible under full throttle after gauge install. Please help!!!!
  40. Timing issue after water pump install
  41. Evo 8 timing belt tensioner pin help
  42. Evo 9 engine head
  43. Do I need a better BOV?
  44. About to have my 8 motor built! Tips?
  45. Soft Clutch Pedal AFTER Bleeding
  46. P0125 trouble
  47. 6466 Turbo Damage?
  48. Check my timing
  49. knock after 2step
  50. Have a weird clutch drag issue. Exedy triple/2.4L
  51. ARP head bolt thread chaser
  52. Wiseco piston ring gap
  53. Blown Headgasket or Bad T-stat
  54. Turbo Issues After New Motor
  55. transfercase identification
  56. Evo 8 Engine Noise - Help Identify Pls
  57. Is it possible for a synapse BOV's spring to break?
  58. sending block to machine shop
  59. Power question
  60. what color is this exhaust smoke ?
  61. evo 8 Trans Guro's ( Syncro sleeve input shaft direction)
  62. Valve cover gasket W/ Spark Plug rings ???
  63. QM 8-leg feels soft after hard launch
  64. 38 or 44mm gate? Stock turbo exh housing
  65. rear dif overhaul
  66. Water jacket in block to head threads?
  67. Help: Need output shaft part number
  68. Lint free rags for engine building?
  69. FP Black swapping over water lines question
  70. Shifting
  71. OEM Crankshaft Hardening
  72. TPS sensor testing help!
  73. Bang for $ - cams vs turbo upgrade on evo9
  74. Spoolinup Injector Connectors
  75. Evo 8 TC/ACD/Front diff noise
  76. rpm's freeze at 6k for 1sec during wot
  77. Weird misfire issue. Need help. Tried almost everything
  78. i am still looking for a 5 speed box
  79. Sounds like a Subaru and runs awful
  80. Oil in Catch Can
  81. Strong engine?..
  82. gains from intakes? (Speed Density)
  83. Blew motor and building a new one questions
  84. Dissembling my TC now - experts please help (sorry long tech help post)
  85. What pistons and CR shud i use for my setup?
  86. Possible fuel pump issue? blown #15 fuse
  87. Bad idle... help?!!
  88. Please Help :(
  89. Odd lean-out under partial load.
  90. Piston ring question
  91. Full blown Vs Buschur Vs TScomptuned fuel pump
  92. Throttle body shaft seal on evo vii
  93. Lambada sensors
  94. New build and oil oil on pistons
  95. Engine Build Question
  96. 4G64 block, part number
  97. Which rear diff is best for me?
  98. High RPM oil pump options - straight cut?
  99. Anyone have trouble with the GSC lifters keeping the valves open???
  100. Turbo Suggestions?
  101. What to go over?
  102. Vac at idle for GSC S2
  103. Full blown wiring
  104. Evo 4 GSR Rear Diff Bushings
  105. Evo 8 oil return
  106. Evo 8 front case help
  107. stuck at the last stage of pulling my TC once again..
  108. Guys who have pulled their TC please help
  109. 20g 5+5 wheel? Compared to 6+6 or 11bladeGTX?
  110. Engine noise after fresh rebuild
  111. Stock Trans + 2.3L Stroker= Problems?
  112. Let's see your high mileage built motors that don't burn oil!!
  113. 4G64 Maximizing Displacement
  114. pulling my Transfer Case, anyone done this?
  115. Need help with some wiring
  116. Vacuum diagram?
  117. Rotating Assembly Refresh with Pics
  118. Question about Shep Trans vs stock trans. (Buying a used evo)
  119. Tilton twin disc lockout?
  120. Replacing that @$#% oil pressure sensor on Evo IX.
  121. evo 8 won't stay on
  122. 8 heat range spark plugs for E9
  123. 2.2 Cam dilemma
  124. HELP: Sounds like I've got nasty cams...But I don't have cams
  125. How do I get to 400whp?
  126. Boost Leak or Miss Fire at WOT
  127. Evo Engine removal without removing transmission or Tcase?
  128. Custom Intake Manifold
  129. Evo 8 deceleration whine
  130. EVO IX front O2 sensor
  131. What headers should I buy??
  132. Short but loud rattling on cold start
  133. Front axle pulled - fluid leak?
  134. STM Fuel Pump Rewire. Relay Heat?
  135. lfr7aix spark plugs cheap on amazon
  136. 2.0 or 2.3L - STC 3030R Turbo
  137. autolite xp3924 autozone spark plugs making sure
  138. FP Zero
  139. BLE solid lifters question
  140. Crank walk...is it safe to say....
  141. no check engine light and wont turn on why?
  142. EVO V rebuild or go OEM?
  143. Oem Lsd install question
  144. ACT clutch problem
  145. Sheepey intercooler fitment issues?
  146. Passenger axle seal leak. Is this tcase fluid or transmission fluid??
  147. How much faster is a dog box
  148. STM master to slave clutch line install questions
  149. evo 9 head on evo 8 block
  150. Which cams to choose
  151. Hello from Vancouver
  152. 1998 EVO V Blown motor
  153. O2 housing for twin scroll setup
  154. evo 3 wheel bearing size?
  155. Opinions of PTE 5858 set up
  156. Varience on injector pigtails
  157. Springs & retainers for S2 cams
  158. Head oil port mod
  159. Should of never cleaned my Maf Sensor!
  160. Long shot: Anyone have this trans issue before?
  161. Need help!!!
  162. The gauge reads 261F & it isnt hot
  163. ATP GTX3076R opinion
  164. cam questions.
  165. 5 SPEED SWAP write up
  166. Trouble issus car wont start
  167. Forced Performance
  168. Tilton Carbon clutch life span
  169. Clutch Opinions
  170. Synapse Synchronic DV - Catastrophic Failure
  171. ARP head nuts cracked! Head gasket failed! Ugh. Help!?
  172. Transfer Case or Rear Diff Gone?
  173. Help me about my LSD
  174. Included parts?
  175. Another engine tick thread
  176. HTA86... .82 vs 1.03 turbine housing
  177. How to waste 2500 hard earned dollars.
  178. Need help! Loud clunking noise coming from front.
  179. High oil pressure at idle
  180. Misfire Issue - Need advice
  181. HELP choosing clutch kit
  182. Stock and Aftermarket turbo
  183. MAF swapped
  184. o2 sensor woes
  185. What am I missing and does anyone have one? LOL
  186. Head repairable??
  187. Exedy 05803HD vs ACT HDSS
  188. Starter shield won't fit over replacement starter
  189. 3 Port Boost Controller to Electronic Boost Controller
  190. 8 GSR 260 - The Upgrade
  191. Aem ems 1 evo rpm cut off at 5900!
  192. Fuel pressure bleed off after shut down
  193. no knock sensor voltage to sensor
  194. 2nd gear lockout
  195. AC problems, I'm stooped.
  196. Tomei Crank Slicer & Baffle Questions
  197. Drop in pistons?
  198. est 100% bolt on turbo today for stock engine with e85?
  199. Evo 9 6 speed
  200. Lsd
  201. Quartermaster 8 leg race discs with street flywheel
  202. Cycling Key To Start?
  203. Mitsubishi Evo 4 pushing out balance shaft/oil pump seal
  204. Any experienced engine builders in so cal area?
  205. Oil to BB turbo
  206. Cosworth Crank Scraper
  207. Please help me with my strange clutch issue!
  208. Fuel Pressure Solenoid Circuit p0090
  209. No fuel pressure
  210. Mivec oil feed line. Alternative oil pressure source.
  211. Buschur double pumper replacement filter socks
  212. EVO 8 Timing Off??
  213. Borg Warner ABS sensors
  214. Acy bleeding
  215. Fuel pressure regulator problem
  216. SE:PA Rear Diff, Axles, Subframe, Knuckles/Hubs
  217. Hi from Australia and a question
  218. Testing coolant temp sensor
  219. Evo 9 coil pack retune?
  220. Blown turbo? install 71HTA
  221. Evo 8 Head Swap
  222. fuel pump set up
  223. Wiseco or CP pistons..which do you prefer ??
  224. code p0090 HELP !
  225. Boost controller?
  226. Evo 8 Rs engine harness
  227. Wastegate actuator arm snapped!
  228. 03 Evo A/C Condenser Fan not turning on
  229. What is the best spark plugs for different setup
  230. BISS Screw Actuator in EVOscan revealing an Issue, HELP, Kind of an Emergency.
  231. Evo 9 leak head gasket
  232. Vacuum Pressure at Idle with my mods????
  233. engine help ( techs? )
  234. Differential
  235. What to use to clean IAC motor?
  236. ACT clutch exploded?
  237. Airtrek/evo Gta torque convertor
  238. Greddy Type24E LS Intercooler Kit
  239. Ball Bearing Oil feed
  240. TOB Not Locking in Wedge Collar (Monoloc)?
  241. PTE5931E MFS on evo anyone???
  242. FP rear housing problems, laggy, low HP, HELP!
  243. Manually turning engine over by hand?
  244. Post Turbo Failure Clean Up Help
  245. Any suggestions or concerns? Thanks
  246. Uncommon Garrett Turbo Question
  247. Engine afr
  248. Xona rotor 82-67 with .63 turbine housing...possible?
  249. HELP! Another clutch pedal to the floor issue
  250. Replaced valve cover gasket yesterday, found a surprise
